I must assume that you confirmed power at the outlet by plugging in a hair dryer or some other type of appliance. If the outlet works the failure in your Kitchen Aid mixer could be a failed speed switch, motor or a loose wiring connection. In order to diagnose the failure will require dis-assembly and checking voltage, the wiring and switch operation using a volt/ohm meter.
