Question about Nokia 6700 Slide Cell Phone
HI,
Please follow the below given navigation path
menu-->settings-->phone settings-->offline mode
select off to remove it from offline mode.
If you have any queries Please let me know
Thank you
Posted on Jul 30, 2011
SOURCE: Nokia e65 stuck in offline mode.
step 1>switch off your phone and turn it on again
step2>you should get a respond <: continue in offline mode>: select no
finally, i believe that everything should be ok.
if it doesn't there is alternative 2???/////
ALTERNATIVE TWO: this is useful for those who got INSERT SIM CARD RESPONSE.
WHY INSERT SIM CARD PROBLEM ?
my phone is 1yr and 6 months now and i discovered that as you remove and replace your Sim card numerous times, there is a big possibility that Sim card port will get expanded.
SOLUTION is very simple:.>>:1. buy a black solo tape
2. place it at the outer part of the sim card and use blade to cut exactly the same shape as the sim card.
3. finally stick the tape.
WARNING>>?do not stick the tape on where you have the Sim card service sensors.make use of your brain.
Posted on Jan 14, 2009
SOURCE: cant access any other GSM card in my nokia 6700 classic
in order for you to use it with a different sim card (carrier) you must buy an unlock code, You can usually find one on ebay, just type on the search box: nokia 6700 unlock code
Posted on Jun 30, 2010
Oct 16, 2011 | Nokia 6700 Classic Cell Phone
Sep 22, 2011 | Nokia 6700 Slide Cell Phone
Feb 25, 2011 | Nokia 6700 Classic Cell Phone
Dec 06, 2010 | Nokia 6700 Classic Cell Phone
Oct 25, 2010 | Health & Beauty
Aug 15, 2010 | Nokia N70 Cellular Phone
Aug 01, 2010 | Nokia 5230 Cell Phone
Jun 30, 2010 | Nokia 6700 Classic Cell Phone
May 30, 2010 | Nokia E66 Smartphone
Nov 25, 2009 | Nokia 6700 Classic Cell Phone
Sep 30, 2016 | Nokia 6700 Slide Cell Phone
Nov 04, 2014 | Nokia 6700 Slide Cell Phone
904 people viewed this question
