Cameras Logo
Posted on Aug 25, 2017
My Samsung SL105 camera will not charge. I plug it into the wall charger and the light turns red, then green, then proceeds to a flashing yellow. I bought a new battery for it (SLB10A) and I'm still having the same problem. I have had this problem since I bought the camera over a year ago. I would be able to get it to charge on occasion, but for the most part, it won't.
Alicia Reichel
Level 1:
  • Contributor 1 Answer
  • Posted on Dec 23, 2019
Alicia Reichel
Contributor
Level 1:
Answers
Questions
Helped
256
Points
My Samsung camera SL105 won't turn on. When I push the power button the lens tries to extend out but won't. Then it beeps and goes back in. What is this from. I got it to open a couple times today but back to same now.
5 Related Answers
A
Anonymous
  • Posted on Jun 06, 2008
SOURCE: My camera won't turn on
I had the same problem...so I called Casio at 1-800-435-7732 and its from the battery itself. They just sent me a new battery because it was a known issue. It took about 4 days to get the new battery and it was FREE.
Anonymous
  • 477 Answers
  • Posted on Jun 12, 2008
SOURCE: Wont Turn on at all - Casio Ex-z750
Contact the person @ www.digitalcamrepair.com he can repair it for you.
Anonymous
  • Posted on Jun 20, 2008
hey! I had the same problem and the only thing I did was take the battery off and then on, and now its working :)
Anonymous
  • 4 Answers
  • Posted on Apr 28, 2009
SOURCE: The battery (NP-20) for my
Okay I just fixed this on my camera the same thing. First make sure your battery is charged. You will need to get a paper clip. Take the battery out and unfold the clip so that you can use it to pull up the contacts between the battery positive and negative and the camera. The conductors need to touch the positive and negative on the battery. If you battery is dead you will need to do this as it will not charge your battery on the cradle becaue there was no connection. over time I think that the battery loses its connection and the spring is not strong enough to push up the battery far enough. I ordered a battery charger and new battery and it still didnt work so I started to tinker with it. I held the battery with my finger pushing it up and holding it, and simaltaneuously powered on the camera. Thats when I figured it wasnt the battery but it wa the connection with the battery and the camera.
hope that helps
David
  • 21 Answers
  • Posted on Sep 04, 2009
SOURCE: Samsung L313 Charging Problem
it sounds like the battery is faulty. try a new one.
tip
Samsung TL205 Battery Charger Samsung TL205 Charger
With the most high-quality camera battery charger,
Description: Home Travel Charger
Input Voltage (AC): 100-240V 50-60HZ
Car Input Voltage (DC): 12-24V
Output Voltage: 4.2V/8.4V
Output Current: 600mA
Dimensions: 1.86" x 3.33" x 1.50"
Weight: 2.5oz (85g)
Color: Black
Features:
A. Direct Plug-In wall Samsung TL210 Battery Charger - No cable necessary
B. Samsung TL210 Battery Charger Output: DC 4.2V 600mA
C. 110-220 Volts - Works in every country in the world
D. AC Car Adapter - Charge your battery at home or in your car
E. Fast Charger 800mA - Charges most batteries in 60-120 minutes
F. LED Charger Indicator - Red light: needs charging, Green light: charging is complete
G. Samsung TL210 Digital Camera Battery with Manufacturer's 1 Year Warranty.
H. The Samsung TL210 Battery Charger is for charging your battery only. It does not work as AC adapter for your camera
on Sep 21, 2010 • Cameras
2answers
Light does not flash when charging battery
Please try this:
1) Make sure camera is OFF.
2) Plug Charger into the wall (not into camera)
3) Last think plug charger into the camera
Battery not charge samsung camera es55
now a wire inside the charger could be snaped at that point u should get a new one
1helpful
Im trying to charge my camera via computer. . there is a red light on the charge cable connector and a green light on the camera which i have switched "on". it still says "low battery even...
Hi, I'd suggest using a wall charger as they're able to provide more power to charge then a computers USB port. Often with camera's the USB port doesn't supply enough power so the camera doesn't charge at all.
How to charge the batterry
the charger port is located under the front of the joystick. with the charger off plug the 3 pin connector into the charger port then turn the chrger on or plug it into the wall. You should see a red and a yellow light when the yellow light turns green the batteries are charged turn off the charger and remove the plug from the joystick See my tip on charging Hope this helps you
3helpful
Pronto M6 chair will not work. When the power switch is turned on, the LED light flash Red followed by three Green. I can't find what this error code meas.... Pls Help thanks Phil
Phil the red means battery is low and the green is a speed limit code because of the low battery if you have charged your batteries and you still get the red then you need to check the charger after charging all night does the yellow light on the charger turn green? if when you first plug in the charger if the red light is on and the other light is green then there is a problem with the wiring or connection to the batteries from the charger and you aren't charging the batteries. if when you plug the charger in and you get a red and yellow light then the charger is working but you don't ever ge a green light and the battery level gauge is still showing red then you need to replace the batteries Hope this helps
When turning power it makes a clicking sound but does not power up. battery charger has a red and green light on. When plugged in and turned on it flashes 8 times. I checked the power control connection,...
The chair will not move if the charger is plugged in. The flashes are normal with the charger plugged into the chair. The lights on the charger mean that the batteries have been fully charged. Red and yellow lights mean charging. After you unplug the charger from the chair (if off-baord charger, turn charger off or unplug from the wall) then unplug from joystick. after plug is removed from joystick press the on button and all the battery lights should be lit and when you move the joystick forward you will hear the electric bake release and the chair should move forward etc Hope this helps
Charging doubts
Personally I would suggest leaving it in the charger maybe even overnight because if I'm not mistaken it should turn green when it is fully charged. good luck
Top Cameras Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Camera Expert? Answer questions, earn points and help others
