Remove the hard drive from the lacie box and plug it in directly to your computer to see if the drive is now recognized. If it is the issue is with the lacie box electronics. If still not recognized with a direct connection to computer, see if the bios sees it. If not, the logic board on hard drive is fubar and you have a serious recovery problem.
SOURCE: LaCie 500 GB hard Drive - does not register on my desktop
if it is a USB (or you have low disc space), it does take longer to show up on desktop and patience is required... on my iBook it takes over a minute for my Brick to show up... Whether it is USB or firewire, do try another cord (I had similar problem with my lacie firewire external... I used a different firewire cord and all was fine. If you have tried these already, I hope you find the answer... good luck
SOURCE: Re: LaCie icon does not appear.
run diskmgmt.msc create a partition then format it. done. if no driveletter .. assign it.
SOURCE: My mac is not recognizing my Lacie 1 TB, it
I had the same issue -- turned out that power supply was going bad so the drive wouldn't spin up all the way; this could explain the strange noises you're hearing. I put in a support ticket with LaCie at their website and they sent me a new power supply at no charge (I was within the warranty period, I think).
