Overheating is one of the frequent causes of freezing and other errors in your HP Laptops. So, if your laptops keeps freezing then the first and the most important thing that you would have to check is whether your fan is working or not. If your fan is not working then you would have to buy a cooler pad for your HP laptop. The cooler pad which sits under your laptop would prevent it from getting overheated.
Switch ON the PC, boot the PC in 'Safe Mode'
by continuously tapping F8 button after just after you switch On until you get Safe Mode Option. A
'System Restore' window will appear. Note:
It is better if you could remember from which date you are facing the issue,
try to select a date prior to that date. The
detail of that particular date should show "System Checkpoint" and
time on the right hand side box. Select that date.
Let windows boot in Safe Mode and log in to windows.
Go to 'Start'--->Programs--->Accessories--->System Tools--->Click
'System Restore'
Here you will have to check "Restore computer to an earlier time' and
click Next
Now you will find one Month Calendar window with Dates below, go to
the previous month by clicking the '<' sign in the upper left hand
corner of the Month Calendar and select any date that you see in Bold.
Now, Click on Next and System Restore will start and windows will take a
reboot.
After reboot your problem should be resolved.
