SanDisk Cruzer Micro 8GB USB 2.0 Flash Drive Logo
Question about SanDisk Cruzer Micro 8GB USB 2.0 Flash Drive
When I insert sandisk cruzer blade 8gb pendrive, it is showing as removable disk but not opening and shows as 0 bytes. All other pendrives are working in my system and this pendrive is working in other systems. I went to device manager and did all that was given in support of sandisk and also I checked with drive letter conflict. Still not working. Please help
Posted by hari_perumal on
richie46
    Top Expert:
  • SanDisk Master
  • 12,962 Answers
Since it works with other systems there is a system incompatibility issue. Are you using the same OS in this machine as in the others where it works? Could it be that?
Using XP? It has some issues with some usb devices.
Posted on Sep 24, 2017
5 Related Answers
Anonymous
  • 200 Answers
SOURCE: hi, i'm not able to
Have you tried a next pc to see if it will read the flashdrive?
Posted on Sep 18, 2010
Sabari Prabu
  • 82 Answers
SOURCE: My laptop is not able
just format your laptop my dear and then use it.......
your laptop may be afffected by virus....
Posted on Jan 22, 2011
Anonymous
  • 41 Answers
SOURCE: Hai, i have a sandisk cruzer micro 8gb
Well I had this problem twice
1: put flashdrive in washing machine
OR
2:go to installed hardwAre panel (something like that) and uninstall the hardware then reinstall ( by reattaching drive)
Honestly I don't recommend option 1 ... But that works too
Posted on Mar 03, 2011
Anonymous
  • 10406 Answers
SOURCE: hello, I have Sandisk Cruzer blade
Copy all the files from it to your 'C:' drive, and burn the files to one DVD-recordable disk.
Then, responsibly recycle the SanDisk, and spend $10 to buy a new flash-drive.
Copy the files from the 'C:' drive, or the DVD disk onto the new flash-drive.
Keep multiple copies of your files, just in case this "new" flash-drive also "fails".
Posted on May 25, 2011
Anonymous
  • 36 Answers
SOURCE: My sandisk cruzer 4 GB
Your flashdrive usually shows 2 drives when inserted to your computer, one is the U3 drive and the other one is the removable disk drives. U3 drive is your separate partition for the U3 system and in order for you to store, copy, format your flashdrive, you should be selecting the removable disk drive, not the U3 drive. U3 is a read only memory drive that is responsible for your U3 to work (just like portable applications). Hope this helps.
Posted on Jul 04, 2011
2answers
My sandisk 8gb pendrive is showing o bytes as its space
It may need to be re-formatted. That is if there is no accessible data.
You can also check for hidden files, by setting you folder options to show all hidden files.
Round radio button on pic.
1helpful
2answers
MY 8GB SANDISK CRUZER BLADE PENDRIVE NOW SHOWS WRITE PROTECTED...PLEASE HELP IF U CAN........
My 8 Gb pen drive now right protected how can i remove the write protection pls.....................Pls..............say the solution
My sandisk cruzer 4 GB pendrive ws working fine but now whenever i try to format\copy\cut it shows location 0 with used space 0 free space 0 what should i do
My transcend 8gb pendrive is not working. when i
hi, try to format the Pendrive and run scandisk command.
right click on pendrive > properties> choose format and when format is finish use check disk.
5helpful
2answers
SANDISK CRUZER BLADE 8GB PEN DRIVE is showing 0bytes of freespace and usedspace memory in properties
Go to Disk Utilities and reformat the pen drive. That might do the trick.
All the best!
1helpful
Transcend JetFlash V10 -8GB when opened shows ''insert disk''
your pendrive is out of order Transcend JetFlash V10 -8GB whenever you purchase a pendrive only
buy a 1,2,4GB
Pendrive get detected but not display items
Your pendrive is infected with Autorun.inf virus
to remove this virus install malwarebytes (It is antimalware software)and scan your whole computer as well as your pendrive when you scaning finish remove all threats
I
Open Questions:
See all SanDisk Cruzer Micro 8GB USB 2.0 Flash Drive Questions
Top SanDisk Electronics - Others Experts
Marvin
Marvin
Mehandi Husain ...
Rob Hill
Rob Hill
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
