Question about Bulova Watch
I have a Bulova watch that was my fathers. I've done some research on it to find out how old it is, but I cant seem to find anything on it. The number on back is 9021137. The inside has 24 jewels, 8AE, and bulova watch co. Any suggestions would be appreciated. Thanks for you time!
Posted by surfgrl5150 on
5 Related Answers
Anonymous
SOURCE: watch casement cover replacement
looking for a battery cover to suit model D 377 tissot men's twotimer II vintage 1992.
Posted on Oct 20, 2008
Jackalltrade
SOURCE: BULOVA WATCHES
Most watches have the gold content engraved inside tha back cover. Open carefully!
Posted on Apr 21, 2009
Anonymous
  • 580 Answers
SOURCE: How do I set the date on an old bulova caravelle men's watch
Pull the stem out 2 clicks the in 1 click turn stem clockwise for day and counter-clockwise for month. to set time pull stem out again 1 click, when finish push in 2 clicks
Posted on Jul 09, 2009
Anonymous
  • 206 Answers
SOURCE: Day, date and time for a Bulova TFX watch
Step 1. When the second hand re a ches 12 o ’ clock (the zero or 60th second mark ) , pull the crown all the way to the “OUT ”position (you will hear two “ cl i ck s ” ) .All hands will stop.
Step 2. Turn the crown to move hands FORWARD (clockwise) until you see the date (for date only) or both day and date change.This establishes midnight, t h e b e ginning of the day.
Step 3. For A.M .time, continue to move hands forward until the minute hand is approxim a t e ly 5 minutes beyond the desired minute marker ;then ,gently turn b a ck to the same marke r. For P. M .time , follow the same procedure ,but first a dvance  the hands past 12 o’clock .
N O T E : The date will advance automatically at midnight, p rovided that A . M .a n d P. M .h ave been established (Steps 2 and 3).The watch calendar is pro grammed for a 31-day cycle.The  refore ,on the fi rst day of any month fo l l owing a month with fewer than 31 day s , the date must be advanced manually (see Step 5).
Step 4. When the time standard by which you are setting your wa t ch ( e.g.,telephone beep) re a ches the 60th second, push the crown all the way to the “ I N ”position . All hands will start instantly.
Step 5. Pull the crown to the “ I N T E R M E D I AT E ”position (one “ cl i ck ” ) . Your watch will continue to tell time. S l ow ly turn crown one way until the correct date a p p e a rs .Then for day/date models, s l ow ly turn crown the other way until the correct day appears .
N O T E : The day is printed in two successive positions on the day indicator: i n English and in Spanish on U. S .m o d e l s ; in English and in Fre n ch on Canadian mode l s It is possible to make use of either position. The display will automatically re m a i n in the language ch o s e n .
The date should never be ch a n ged manu a l ly between 9:00 P. M . and 3:00 A . M .a s this might affect the calendar mechanism and the accuracy of the date. ( Theme chanism will not be damaged if the crown is turned accidentally during this
time peri o d ,howeve r. )
Hope it helped U!
Posted on Jul 30, 2009
David Tolond
  • 2501 Answers
SOURCE: Bulova 14k Solid Gold woman's watch. Swiss 17
This sort of information is only likely to be available from an authorised dealer.
If you go to the Boluva web site, you will be able to use their dealer locator to find the one nearest you.
Posted on Mar 17, 2010
97T59
retail price is $250, its not a popular watch to fake
Jul 15, 2014 | Bulova Bracelet Watches
I have a Bulova Watch that was given to a Clark Candy employee with a Serial Number of 523791. Looking for what year it was made and is it worth anything
The value of your watch depends greatly on the model / style, age, and case composition. It goes without saying, but watches (of any mechanical quality) that have real gold cases right now are worth quite a bit more than watches with gold plated, gold filled, gold-tone, or stainless steel cases. Presentation watches like those given to employees upon retirement were often gold or gold-filled--but there's a world of difference in value between those two types of watches.
In terms of age, it's much easier to date vintage Bulova watches by their "year code" than by their serial number. If you look carefully, usually above or below the serial number, you'll see a little alphanumeric code, like L5, N3, or P6. These can be translated as follows:
Lx = 195x Mx = 196x Nx = 197x Px = 198x Tx = 199x
Pre-1947 Bulova watches used little symbols to show the year of manufacture. A picture of those codes can be found here, as well as elsewhere on the Internet:
http://www.manleyhorlogerie.com/Watch_History/bulova.htm#Bulova%20Date%20Codes
Jul 24, 2011 | Bulova Watches
I have an old Casio watch 863 SDB-500W, I have just change the battery . Light is working but nothing is display. How to reset it ?
To reset the watch, you need to 'short' the reset point with the battery. To do this, with the watch face down and the back removed the 'Reset' point is in the bottom right hand corner (a gold-coloured contact point). Use a pair of metal tweezers or an unbent paper-clip (anything as long as it's metal and will touch the reset point and the back of the battery at the same time). Maintain contact for about 5 seconds and you should get the display back.
I've just changed the battery in my SDB 500W and the above method worked. I did lose the audible 'beep' though and I'm currently on the net trying to find how to get it back. That's how I found your question... :)
I have a antiqe bulova serial#1769634 need to know more
some Info with pics on old Bolovas can be found here 'http://www.mybulova.com/search-bulova-watches' the first 3 numbers of your case S/N returns a 1971 Accutron Astronaut Mark II.
Jun 16, 2011 | Bulova Watches
We have 3 women's watches. serial numbers
Bulova is an American company founded by Joseph Bulova in New York City in 1875. Most watches are currently manufactured in Woodside, Queens, New York. However, the European collection, including Accutron watches, are made in Switzerland.
Read more: In which country are Bulova watches made? ' Answerbag http://www.answerbag.com/q_view/1988925#ixzz1OmH0p4sb
Jun 08, 2011 | Bulova Watches
Bulova automatic How old and value.....number 3865924
To get exact age and price, follow this link:
http://www.bulova.com/brands/bulova/bulova.aspx?brand=bulova
At the bottom of page you will find CONTACT US. Just click on it .
Rate me, please.
Aug 05, 2010 | Bulova Watch
I have an old bulova watch and i have the serisl number and would
For most specific info call the Bulova hotline.
1-800-ABU-LOVA
Jul 24, 2010 | Bulova 95U08 Wrist Watch
My Bulova quartz wrist watch, inherited frommy father, has just stopped working. Where to get it repaired in Geneva?
Found an email address in Switzerland for Bulova. Contacted them and they've given me the name & address of a Bulova dealer here in town.
Oct 07, 2009 | Geneve Watches
Bulova Watch Logo
133 people viewed this question
Top Bulova Watches Experts
Janelle Schoonover
Janelle Schoonover
Bruce Robin
Anthony Ward
Anthony Ward
Are you a Bulova Watch Expert? Answer questions, earn points and help others
