Question about Akai LCT2662 Television
My tv used to have a red light to indicate when the tv was ready to turn on after i flipped the main power switch. Now the red light will not turn on unless i flip the main power switch on and off for at least 20 minutes. What is the problem and how can i repair it?
Posted by zachahartley on
Tyler Bearor
    Champion:
  • 367 Answers
Did you get this fixed?Please let me know.Thank You very much!
Tyler
Posted on Sep 17, 2011
Why would gould water pump red trouble light indicator come on when power switch turned back on after having been off for a few hours? Had to turn off power to pump earlier in day due to volatile elec
check and prime the pump as the light may indicate no water and so the pump will not run
foot valves leak back the water so it may need priming again
Jul 21, 2017 | Cars & Trucks
KDF-60XBR950 Red light blinks 5 times
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Apr 01, 2017 | Sony Grand WEGA KF50WE610 50" Rear...
Constant flashing red light near main on/off switch
A constant flashing light near the main power switch normally indicates a problem with your device's electronics, ranging from image board errors to power supply failures.
It is best to contact the manufacturer's customer support line to get the appropriate trouble codes and best advice.
Hope this helps.
Nov 05, 2013 | Panasonic TH50PZ80BCAB 50 in. HD-Ready...
Not turning on
The power supply has failed.
Nov 27, 2012 | Akai LCT3201AD 32 in. LCD Television
Sharp model lc-20sh1u won't turn on, just makes a clicking sound and indicator light flashes red.
The clicking sound may be a power relay coming on and then off--problem indicates a trouble in the main power supply.
Nov 02, 2012 | Sharp LC-20SH3U 20 in. EDTV-Ready LCD...
Red power indicator light is blinking
The flashing light indicates a short circuit inside the power supply circuitry. This type of repair is not a DIY without a multimeter, desoldering iron and hand soldering skills. I repair these power supplies, if you need further info write to [email protected]
May 26, 2009 | Akai LCT2701TD Television
No power no picture no sound Astar LTV 20PW
Hello friend,
Your tv can be fix, I am the right person could help you fix your tv.
please call 323-767-6030.
Jan 03, 2009 | Astar LTV-20PW 20 in. EDTV-Ready LCD...
26PF8946/37 Red light
Hey habo,
The red light you are referring to most likely is the power indicator light. On many newer TV's this light will appear red when the TV is off or in "standby" mode, and green when the TV is in operation.
Please keep in mind that some TV models may use the power indicator light to notify owners of ay potential hardware problems as well, so you may wish to refer to your owner's manual documentation if you have been encountering any problems during TV operation.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Jul 22, 2008 | Philips 26PF8946 26 in. HD-Ready LCD...
Samsung series 550 1080 hdtv power problem
Is the TV main switch turned on?
There might be a main power switch on the TV somewhere.
Jul 16, 2008 | Samsung HCN4226W 42" Rear Projection...
Akai LCT3201TD
Most failures of this nature are with dying or defective power supplies.
I service these power supplies. If you need more info, my email is [email protected]
Oct 14, 2007 | Akai LCT3201TD 32 in. LCD Television
Akai LCT2662 Television Logo
Top Akai Televison & Video Experts
Ekse
Marvin
Marvin
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
