Question about HP Photosmart C7280 Printer
Error 0xc05d1281 in HP photosmart C7280 - HP Photosmart C7280 Printer
Posted by rickjan01 on
Gopakumar D
  • 109 Answers
Hi............
pls click here for solution
thank you.........
Posted on Jul 29, 2011
Testimonial: "great"
Jessica Michael
    Master:
  • HP Master
  • 459 Answers
Please make sure that the printer is connected directly to the wall outlet and not to the surge protector.
Step 1: Remove all the ink cartridges and then try to perform a hard reset on the printer.
Step 2: With the printer turned on, disconnect the power cord from the rear of the printer and also unplug the power cord from the wall outlet.
Step 3: Remove USB cable, if present.
Wait for 2-3 minutes, press and hold the power button on your printer for about 30 seconds to remove any additional charge.
Step 4: Now plug back the power cable straight to a wall outlet without any surge protector or an extension cord and then plug back the power cord to the printer.
Step 5: Turn on the printer and wait till warm-up period finishes and the printer is idle.
Step 6: Now insert the ink cartridges and then try to print a test page and check if it works.
Step 7: I will be sending you the steps for the Semi-full reset as a private message, which restores the printer to original factory default settings.
Please try these steps still have issues Call Our Toll-Free 1-888-224-4280
Posted on Sep 07, 2018
3 Related Answers
dgsturt
  • 1705 Answers
SOURCE: HP Photosmart c7280 all in one can't be found
Assuming its all connected and powered up, try re-installing the drivers.
Posted on Jul 21, 2010
siskin68
SOURCE: I have a HP c7280 printer, which is making funny
The noise may be generated by a gear which has fallen off the shaft. The mount then grinds the gear of the printhead.
If that happens, open the left cover of the printer, find the gear in the unit and bring it back into the shaft. Just clip.
Then
clear hardware failure status as described.
Posted on Sep 08, 2011
HP c8180 error code oxc05d1281
http://h30434.www3.hp.com/t5/Other-Printing-Questions/0xc05d1281-Error-code-for-Photosmart-C8180/td-p/1212853
Apr 10, 2015 | HP Office Equipment & Supplies
HP C7280 printer: "Pump motor stalled" error
This means there's a failure in your printer's pump motor.
If you are still under warranty, contact HP's Customer Service here : http://welcome.hp.com/country/us/en/wwcontact_us.html
If not, you can try your local computer store for a check-up but they'll probably suggest a new printer.
Hope this helped.
Please rate :)
Mar 04, 2011 | HP Photosmart C7280 Printer
0XC05D1281
0XC05D1281 Problem with the HP Photosmart C7280 Laser Printer 0XC05D1281 Help me
Jan 29, 2011 | HP Photosmart C7280 Laser Printer
Jul 21, 2010 | HP Office Equipment & Supplies
Display says error 0xc05d1281
The "Ink System Failure" error is causes by air in the ink feed tubes. We have a step by step guide purging the air from the feed tubes posted on our web site. Go to our site at: www.ccl-la.com , click on the printer repair link and then the HP link. Follow the steps and you should be back printing in no time at all.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Jan 03, 2010 | HP Photosmart C5180 All-In-One InkJet...
0xc05d1281 HP-C7280 Ink System Failed -- tried clearing the error status still same problem, also noise from the print head sounds like plastic gears sliping, print head moves back and forth gears slip and...
printer did not tell about empty cartrigde it just showed that the black was low but not empty -- decided to replace the cartridge early and that ficed the problem!! ?????
Oct 19, 2009 | HP Photosmart C7280 Laser Printer
Ink failure
put ink cartridges in the printer
Jul 20, 2017 | HP Photosmart C7280 Laser Printer
HP Photosmart C7280 Printer Logo
1,625 people viewed this question
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
