Question about Acer Aspire 5535-5050 Notebook
Is my sound card damaged? My sound driver is present and i think it's working fine, sound bars are moving also when i drag the slide up and down. But, theres no sound coming from built-in speaker and, when i insert the Headphone jack, an annoying very low sound coming on to it. My speaker is good, i plug it on my cellphone and it works well. Is that my sound card has a problem? Does it have damage? Or it was naturally cause of improper use.
Posted by lik000012 on
  • lik000012 Jul 30, 2011
    Is there any other alternative way to fix my sounds?
    do i really need to pull out my old sound card and replace it with a new one?
    before that, thanks for reading my post, i didn't expect that someone would reply on my thread.
    thanks anyway..
DNA Computing!!!
  • 304 Answers
Based on the information you have provided, it seems that the issue might be with the Audio Output Jack.
Usually some Computers have an additional Audio Jack on the CPU.
If you have such an option you can try connecting the Speakers and Headphone to that Audio Port and check.
If you do not have an additional Audio port, then it is confirmed that the issue is with Audio Output Port.
It is recommended to replace the Sound Card. You can also check with your favorite Computer Retailer, if only the Audio Output Port can be replaced.
Please let me know if you have further questions or need any assistance.
Suresh....
Posted on Jul 29, 2011
Tip
Top 10 most useful secrets in Office
Here are my top 10 most useful secret ninja moves to increase your productivity and win friends and lovers.
#1: Format painter (Office) The Format Painter tool replicates the formatting from one part of a document to another. So instead of manually redoing all the formatting yourself, you can use the Format Painter. First, select the text whose formatting you want to replicate. Then, click the Format Painter toolbar button. Finally, select the text you want to imbue with the format. For bonus points, you can double-click the Format Painter button to replicate the formatting to multiple areas of the document!
#2: Paragraph in/out/up/down (Office) You can easily move a paragraph in four directions by pressing Alt+Shift+[Arrow]. To increase or decrease the indentation level of a paragraph or bullet point, press Alt+Shift+Right and Alt+Shift+Left respectively. To move a paragraph up or down, press Alt+Shift+Up or Alt+Shift+Down. This works especially well in PowerPoint, where it's common to reorder bullet points or change indentation levels.
#3: Increase or decrease font size (Office) To quickly increase the font size of selected text, press Ctrl+Shift+>. To decrease the size, press Ctrl+Shift+<. I find it easy to remember these keyboard shortcuts because the one with the greater-than symbol increases the font size while the less-than symbol decreases it.
#4: Quick Access Toolbar (Office) Office 2007 has a Quick Access Toolbar that can be customized to include buttons for your favorite commands. The Quick Access Toolbar is in the top left corner of many Office applications. You customize it by clicking on the drop-arrow on its right.
#5: Fill handle (Excel) Excel can auto-fill cells in eerily smart ways. Instead of manually typing a sequence in cells, you can simply type the first few values of the sequence and drag the fill handle to auto-fill the rest of the cells. The fill handle is the little black square at the lower right corner of a selected cell's border. Drag it to automatically fill adjacent cells.
If you drag the fill handle with only one cell selected, it will repeat that cell's value into adjacent cells. However, if you drag the fill handle with multiple cells selected, Excel is smart enough to figure out the series. For instance, in the following example, Excel will fill subsequent cells with the increasing series of odd numbers. This even works for other types of series, like dates and percentages.
#6: Moving and copying cells by dragging selection borders (Excel) Quite possibly the most useful yet completely undiscoverable feature in Excel is the ability to move and copy cells by dragging selection borders.
For instance, to move row four between rows one and two, select row four and drag the selection border while holding down the Shift key in order to insert it in its new position. If you drag the border without holding down the Shift key, the selected cells will instead replace the cells you drop them on. Conversely, if you hold down Ctrl while dragging a selection border, the selected cells are copied to their new location.
#7: Status bar statistics (Excel) The status bar in Excel shows handy statistics when multiple cells are selected. In Excel 2007, the status bar shows the selected cells' average, count, and sum. This is an easy way to quickly analyze data without authoring formulas.
#8: Clear formatting (Word and PowerPoint) To remove formatting from selected text, press Ctrl+Spacebar.
#9: Advanced field search (Outlook) In Outlook, you can quickly search through a mail folder by using the Instant Search box. In addition to searching for keywords, you can do a fielded search by prefixing your search text with a variety of field names.
For instance, the above example searches for all mail from people named "jimmy" sent in May with attachments that have "jpg" in the filename. I most often use this feature for two things: to easily find email from a specific person, and to find specific attachments.
#10: Presenter view (PowerPoint) PowerPoint has for many years had a great feature called Presenter View, which allows you as the presenter to see a different view of the presentation from your audience. In Presenter View, your monitor shows not only the slides, but also your notes as well as the current elapsed time in the presentation. This makes giving a presentation far easier. To enable Presenter view, go to the Slide Show ribbon and check Use Presenter View. In that same section, you can also change the monitor which the presentation is shown on. One note: the Use Presenter View checkbox can only be checked if you already have a second monitor connected and enabled.
on Dec 29, 2009 | Computers & Internet
The chain has came of and for the life of me I cannot seem to get it back on
If the saw chain was run to long loose it wil damage the driver links on the chain. If the drivers want to sit on top of the groove in the bar opposed to sliding easily in it they are damaged and a new chain is required. If this is not the case you will need to find the tension adjuster screw and turn it to move the bar back toward the sprocket till you can slip the chain on to the bar and then turn the adjustng screw the other way till the slack is removed. Then with heavy gloves on grab the chain and move it around the bar. If it will not move loosen the adjuster till you can.
Aug 12, 2013 | Garden
How can i unlock my nokia 5800 . i slide the keypad down and it says ''slide keypad down to unlock '' i even took the memory card and battery out but still doesn't work ?
In Nokia 5800 there is slider key on left side wall of you handset.Press and drag it to down ward once to Unlock and to Lock Drag it once again .
Aug 16, 2011 | Nokia 5800 XpressMusic Smartphone
Very low volume HK 695-01
There are several ways in which you can increase the volume.
First, the most obvious way is to use the volume control attached to the speaker unit itself. If that isn't working, there's also an icon in the lower right-hand portion of the task bar in Windows. Simply click the ^ button, select the icon that looks like a speaker, then drag that up to your desired preference.
If that doesn't work, click on Start, go to Control Panel, click on Sound, then search for your Speakers in the "Playback" tab. First, make sure it's set as your Default Device. There should be a green check mark in it. Double click on those, select Levels, then make sure Play Control is set to maximum.
If that doesn't work, then check the settings on your Sound Card. Make sure the wire going into the back is plugged in properly. You may need to update your sound card drivers. If you aren't sure who the manufacturer of your sound card is, you can find out by going to Start > Control Panel > Device Manager. The Manufacturer will be under Sound, Video and Game Controllers.
Once you have that information, you can go to the Manufacturer's website and update the Drivers. If this doesn't resolve the issue you are experiencing, or if you require more specific / additional information, simply respond to this thread. I'll be happy to assist you further.
Regards,
Aaron Busch
Senior Tech of LiveFix Support Services (LiveFix.net)
May 03, 2011 | Harman Kardon HK695 Computer Speakers
No sounds
Several things to try.
First. Make sure it's plugged in, turned on, and turned up. (double check, this is way more common than you think)
Second: Make sure you're sound isn't software muted (check your taskbar) and make sure the system sound is turned up (on most operating systems this is done by clicking the speaker symbol on the taskbar and dragging the slider bar up)
Third: Unplug from the computer and plug back in and reset the computer.
Fourth: Make sure your sound device is enabled (the following is for Windows 7, please reclarify if this is not your operating system). Click Start>Control Panel>Hardware and Sound>Sound. Right click any empty space in the sound tab box and click "Show Disabled Devices". If "speakers" are disabled, right click and enable.
Fifth: Reinstall your device drivers. You probably have a CD with the drivers, alternatively you can go to the manufacturer's website and download them from there.
Shout out if none of that works.
May 02, 2011 | JBL CREATURE II Computer Speakers
Sound problem in my intel d865gsa.Ive updated and reinstalled my sound driver sound doesnt work
Try to upgrade your BIOS, then uninstall and reinstall the sound driver again. If that doesn't work, you'll likely need a new sound card.
Mar 21, 2011 | Intel Computers & Internet
No sound
i think u have use the sound card but u do't have install the sound driver in your pc that's why sound not working first u have to install the sound card driver in your pc and than after u can see sound working or not....
Apr 06, 2009 | Computers & Internet
Acer Aspire 5535-5050 Notebook Logo
94 people viewed this question
Lee Hodgson
Lee Hodgson
Gustavo Ortiz
Gustavo Ortiz
Michael Thomas
Michael Thomas
