Ask it at the Cooks Essentials manual search agency. I think they will get it soon.
SOURCE: I have had this Cooks
Service and Repair
1-800-233-9054
Repair Department
550 Business Center Drive
Mt. Prospect,Illinois 60056
This is on the back of the manual, hope it is still correct.
SOURCE: Broken gear on BFP-703 base
The drive is replacable and available from Cuisinart, you will have to sign a waver to get the part. the drive is screwed onto the motor shaft with reverse threads. the plastic drive will have to be completely broken off of the unit to expose a brass"nut" which was internal to the drive. depending upon your model you may have to remove the lower half of the base unit to access the lower part of the motor shaft. there will be a slot in the end of the shaft for a large flat blade screwdriver. this is used to hold the shaft still while turning the drive "nut" with a vice grip pliar or similar. the new drive is just threaded onto the shaft and normal operation tightens it.
SOURCE: Black & Decker BL1900
I had to call Black and Decker directly 800-231-9786 to order the part (called the "collar"). It was $14.95 w/ shipping and handling!! Seems pretty steep for a piece of plastic.
SOURCE: The plastic base bowl is cracked on my Puck
www.wpcookware.com is the Wolfgang Puck website. They sell parts to the immersion blenders. The shipping is costly though.
SOURCE: need a manual for Cook's
I will suggest you check manualsonline.com for the manual of your blender.
