There must be some error message when you try to write a CD. What happens when you press the 'create CD' button?
Regarding the other issue, you must have a valid digital input connected for the Alesis to lock on to. PCM digital at one of the sample rates specified on the front panel. If you try to feed it a non-PCM digital signal, such as Dolby Stereo, some other Home Theatre format, or other, it will not accept it. Must be 16-bit or 24-bit, 44.1 to 96kHz as per front panel.
SOURCE: digital input not working
is ther ea digital input present?
please don't take this the wrong way. if no input is present, the masterlink will not switch.
dave
SOURCE: My masterlink won't let me select digital input.
reload the os. it is avail on the alesis site.
the o.s. may be corrupted and a reflash is what it needs. if the issue persist, the HD may need to be replaced.
i posted in another problem about the o.s. since the unit is o.s. driven try it first. it, may be corrupted.
next would be the HD.
you will need to burn an image cd for the masterlink. most cd programs can do this. if you cant, send me an email.
[email protected]
dave
