Question about Wharfedale Diamond 8.3 Main / Stereo Speaker
I won't bore you with the long, tedious reasons for the question, but I need help in connecting the amplifier cables to my Wharfedale 8.3 speakers. There are 4 connection points on the speakers: two red and two black, marked HF and LF. I have one cable with two wires to connect to each. What goes where? The connectors on the speakers also have a small gold coloured plate on them. Should this be kept on or taken off? Thanks!!
Posted by n3_biker on
David Dunn
    Brigadier General:
  • 8,546 Answers
Leave them in, do some reading on Bi-Wiring (BUY Wiring), chuckle to yourself and enjoy the sound. Connect one positive to a positive and one negative to a negative. With the jumpers in place there is no electrical difference.
Posted on Jul 29, 2011
Need manual for Wharfedale Linton 3XP speaker please. Stephen.
Stephan, I don't think there are any manuals around from the Wharfedale. In the seventies of the last century, speakers did not have manuals. I remember they came in a cardboard box, and the only thing they added was a paper, with the impedance and the power handling. And nothing was measured to a certain standard. I know you could destroy a 200 W speaker with a 25 W amplifier, taken you did put in the right (for the speaker the wrong) frequencies. Or what destroyed most speakers, was the certain switching on the amp. You recognise this on: you can't hear the CD player, pump up the volume to the max and then discover you are still on AUX. then without lowering the volume, switch to the CD and the full power comes to the speaker, putting the cones through the baffle.
The Linton 3XP, could handle 30 watt on 6 ohm. Putting it on a 8 ohm amplifier capable of 30 watt should be fine.
But what it is worth? My Kef Concerto's I bought in 1972, are still running. The were rated at 8 ohm for an amp of 25 watt, and the last 15 years they are connected to a 2 time 150 watt amplifier and often put to the test. They still sound as new. Or perhaps even better. No modifications, no new speaker, everything as bought 42 years ago.
If you think something is wrong in one or both your speakers, because you hear strange things, perhaps there are just some bad contacts in the cabling or in the filter. Check everything for bad contacts (soldering) and check the capacitors on the filter. Can't be much of a problem to find out what they used.
I did an extensive search in my documents, but even I can't find anything in my documentation.
I do remember, the brochures in those days were much better then the documentation delivered with the audio stuff.
And if you have a huge amplifier, don't hesitate to plug them on, but always be secure before switching on the amp. Learn to use any switch after you lowered the volume and you will be fine.
Success.
Oct 29, 2014 | Audio Players & Recorders
Need connecting wiring for sony am/fm jx 285 connecting to the sony stereo amp ta-ax 285
If you are trying to connect a ribbon cable tuner to a conventional RCA input terminal amplifier, it won't work because the ribbon cable carries the signal output as well as the data for frequency synthesis which is determined by the processor located in the amplifier ( that is supposed to work with that type of tuner), and the data buss for the buttons on the front of the tuner.
For the time and effort to put into a workaround, it is cheaper by far to get a tuner that will work with your amp. If cosmetics are not an issue, brand of tuner will not matter as their outputs are "Line Level" or nominally 1 volt peak to peak..
Oct 27, 2012 | Sony TA-FE370 2-Channel Amplifier
I have been given a Technics system with tuner (st ch7l), cd (sl ch7), amp (su ch7) & tape deck (rs ch7) with 2 Bi wire speakers! But I have no ribbons or speaker connections! Can anyone tell me where...
What AJIN GOPAKUMAR says.
You can buy cables and speaker wire at Best Buy, Wal-Mart, Parts Express or Amazon. Even a "dollar store".
One thing to keep in mind - do not fall the hype of people who want to sell you very expensive cables because they will sound "better". $2-8 for a set of RCAs should do nicely.
You don't need Monster Cables or their even more expensive brothers. There are many cables that fit your needs. One example on Amazon is "Hosa Cable CRA202 Dual RCA To Dual RCA Cable - 6.5 Foot". Another is Parts Express's "RCA Patch Cable 6 ft. Gold Plated" for $1.80 plus shipping.
More expensive cables will not hurt anything. But they won't help anything in your set-up.
And keep them short, if you can, for neatness ... though long ones won't hurt anything.
Before you buy speaker cable do some measuring ... and add several feet. You will be just fine with lamp cord or zip cord from a hardware store. "Speaker cable" is the same thing with clear plastic covering, often color-coded. This can be helpful because the most important thing to know about wiring speakers is that the MUST be in-phase -- red to red and white-to-white, or plus-to-plus and minus-to-minus. THIS IS VERY IMPORTANT! Check and double check!.
Oct 24, 2012 | Audio Players & Recorders
Splice Bose speaker to connect to receiver
Each speaker has two 4 Ohm drivers. Each speaker has a connector with 4 pins. From left to right they are + - - +. Say 1 2 3 4 . If you want a 8 Ohm speaker connect 2 and 4 together. Now 1 goes to your amplifier (+) and 3 to your amplifier (-). In yor case join black with blue. Now red goes to the amplifier red and green to the amplifier black.
Nov 27, 2011 | Bose Cinemate Digital Home Theater System...
Using this product to play only DVDs at this time. The volume is not very loud, even at 100%. Can one add side speakers by plugging same into the set? How? Will it make a difference
If it has audio OUT ports, you can use RCA cables to connect it to an amplifier; then you can hook up speakers to the amplifier. If it's one of those tiny units, then it should have a headphone jack, in that case, you would connect to the amplifier using the headphone jack. If you want to go cheap, you could hook it up to amplified speakers, but it won't sound as nice.
Jul 26, 2011 | Televison & Video
Hey there. I own a pair of Philips SHL8800s (great bass btw), and after 2 months of use, the left side stopped working. The right works great, as usual. I read Grubhead's post and tried to determine...
it's prob a loose wire inside. however i dont recommend you repair it at home. it's tedious work and it won't look good after. suggest you get it repaired.
Jul 12, 2011 | Audio Players & Recorders
I've just been given a Wharfedale S-990 Amplifier, Tuner CD etc tower - but without any speakers. Output is 2x50W - but the impedence isn't specified. I'm just looking for advice on what...
Anything in the neighborhood of 8-ohms will usually fly safely with standard audio amplifiers. At only 50w x 2 you want efficient speakers. Watch the volume as this amp may clip if driven too hard. THAT will kill any speaker.
This owner had Valdus 200's and was happy. But just about any quality speaker in the 100w range should work out.
http://www.avforums.com/forums/hi-fi-systems-separates/368695-wharfedale-s990-any-good.html
Jun 22, 2011 | Audio Players & Recorders
Hi i" ve bought on
This may help. If it's not the exact model you have it will at least get you started as subwoofers are pretty much teh same for connection and operation.
http://www.wharfedale.co.uk/Portals/0/PDF_Data/Manual/DIAMOND9_range.pdf
Others here...
http://www.wharfedale.co.uk/Support/Download/Manuals/tabid/71/Default.aspx
May 06, 2011 | Wharfedale SW150 Subwoofer
Wharfedale Diamond 8.3 Main / Stereo Speaker Logo
217 people viewed this question
Top Wharfedale Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Wharfedale Audio Player and Recorder Expert? Answer questions, earn points and help others
