Question about Sony KP-53S65 53" Rear Projection Television
Tv showing double image and color messed up - Sony KP-53S65 53" Rear Projection Television
Posted by cassandrabsc on
AAA TV Service
    Sergeant:
  • 271 Answers
Sounds like convergence problem. Fixing the problem requires removing, desoldering and soldering the convergence ICs.
The repair for this may go for a couple Hundred or more..
Best of luck
Nour Sabre
WWW.AAATVSERVICE.COM
Posted on Jul 29, 2011
Double images on screen
IT SOUNDS LIKE A PINCUSHION PROBLEM. IN MOST CASES IT IS DUE TO CAPACITORS GOING BAD ON THE BOARD. OTHER TIMES SOME TV'S HAVE LARGE MICROCHIPS THAT RUN THE PINCUSHION AND COLOR SYNC. HOPE THAT HELPS.
Feb 20, 2010 | RCA HD52W56 52" Rear Projection HDTV
The picture is showing a double image and is distored.
The problem you are refering to is more than likely a convergence problem. The convergence circuit in your tv is controlled by an IC (integrated circuit) stk392-110 and it makes the 3 colors (red, blue, green) line up/converge together to create a clear picture. You'll know when this part needs to be replaced because the picture you see is 3d looking and possibly bowed on the top or bottom or on the sides in any or all 3 colors.
Jan 24, 2010 | Mitsubishi WS-55511 55" Rear Projection...
My tv is almost 6yrs old and all of a sudden the picture is blury almost showing double images. The color is also of at the top and bottom of the screen.
this is typic old projection tv, some tecnical ajust parameters have reset, so if you can adjust,this settings on service menu on tv, or ask for help on local repair store, to calibrate scren.
Nov 29, 2009 | Televison & Video
Toshiba Big Screen Tv Has Bad Colors
this is a rear projection tv not lcd the color is off because the convergance chips are bad take the board out that has the tow stand up chips attached to heatsinks out order the stk number search for on google then take a om meter check all the resistors aroung the chips replace them also you must be a excellent soilder person or a tech to install and remove these chips
Oct 19, 2009 | Toshiba 32 AV 500 PG 82cm 32 in. LCD TV
Color is separating (red and Green double images
Yes everything is repairable.....
The problem is in the Croma section of the TV
some times it ma happen due to 99% of moisture.........
Try Hot air Blow drying for 1 HR in side the TV i.e on the circute and blow clean if any dust partical are there
and then re check
if the problem prestis....contact the TV repai expert or the service centre....
May the Croma chip needs replacement....
Regards
Sep 20, 2009 | Mitsubishi WD-52525 52" Rear Projection...
We have recently bought a Philips Rear Projection TV. It is used, though in good condition when we viewed it prior to bringing it home. Upon setting it up, we found that the color was severely off and...
you may want to call in a repairman to correct the resy of the problem so that its done right the first time and you dont have to keep messing with it if you want it to look as god as possible
Jan 19, 2009 | Televison & Video
Picture is distorded.it shows a shadow of the image in different
Hi,It sounds like the convergence is out on your tv if it has been moved recently this can cause this problem but it really needs a technician to examine it.
SUPER8
Jan 02, 2009 | Philips Magnavox 51MP392H Rear Projection...
56 inch projection tv
This is a convergence problem. If you would please post the make and model, I can provide you with some details about the probable defective parts etc.
Thanks,
Dan
Sep 08, 2008 | Akai Televison & Video
Image double
convergence issues. i see this alot at the shop. i first suggest you read the article i wrote on the fl231 problem in my profile under tips and tricks. this might be a simple inexpensive repair. if this dont apply or help let me know and i see what i can do
Aug 16, 2008 | RCA R52WH73 Projection Television
Hitachi TV Problems
convergence ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 23, 2007 | Hitachi 43F300 43" Rear Projection...
Sony KP-53S65 53" Rear Projection Television Logo
49 people viewed this question
Top Sony Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Nasir Muhammad
Nasir Muhammad
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
