This can be confusing and you're not the first to ask. To put it simply you can only program the timer to turn the unit OFF while it's running. For it to turn ON again, say in 4 hours. You have to wait until the unit is in standby mode, then advance the timer to 4 hours. Four hours later it will turn ON and start functioning.
I hope this helps you and thanks for choosing FixYa.
Thank you for your post, friend!
I see that your question is if the fan should shut off once it has reached the recommended setting. The fan will run even when the compressor cuts off so that air can pass over the sensor coils to check the humidity. This is a normal operation. I hope this is helpful. -Matt
