The adapter is only used for when you need to us it with your computer. Most computer don't have a slot for a micro sd card, and this is why most micro sd card comes with an adapter.
to can put the micro card into a adapter card that you use to put your phone info onto your computer and there is a switch on the left side of the adapter put it into the unlocked position which I believe is up and then take out ur micro card it should be unlocked. I know Kodak SD cards have this feature with the adapter I unlocked my micro card this way
1. Purchase a micro-SD card with an adapter for a normal-sized SD card.2. Plug in the micro-SD card to the back of the phone. Make sure the power is off when you do this, of you could unintentionally harm your phone.3. Power back on, and transfer the pictures to the micro-SD card.4. Shut the phone back off and remove the card again. Place it into the adapter. If your Gateway laptop has a SD card reader: 5. Put the adapter into there.6. Transfer the pictures to you computer. Done! If your laptop doesn't have a SD card reader: 5. You'll need to purchase a second adapter that adapts the regular-sized SD card to a USB port.6. Following the manufacturer's instructions, put the SD card into the second adapter.7. Transfer the pictures to your computer. Done!
That depends on the camera. If the camera supports Sandisk Micro, then the SD card will fit into a slot. The slot is often located near to the battery.
You will just have to push card in and camera will automatically read card.
If camera does not read the card, ensure that the camera model can support SanDisk Micro, and that it will also support card size. Older cameras do not support big memory card (eg.4Gb)
Don't know the size of the micro with its adapter, but if it is the size of a duo card you should be able to put your micro with adapter into a Pro adapter and this is the memory stick that most card readers accept. Sony has been pretty much backward compatible so I feel this should work. A Pro adapter runs about $10 @ Best Buy.
THIS WILL MAKE YOU LOOSE ALL FILES!!!
(even password)
Take the memorycard out of the phone and,
put it in a computer.Use filesystem FAT-32
to reformat your memorycard.
Now the card will work again!
No password, No files will be left after a
complete reformat
This is your solution! Please vote!
Well as far as I know you have to connect the memory card into the adapter and connect the adapter to a card reader(a kind of a box like thing which only that can read the memory cards). This card reader you have to connect to the computer and just copy and paste the song and then reconnect
Any probs just let me know!?
