2000 Ford Mustang Logo
Posted on Jul 28, 2011
I have a 2000 Ford Mustang with a Black Widow security system. I have had a problem with the battery this past week as the car had to be jumped. I replaced the battery and now it won't start at all. My security system has been acting strange for a while but I thought it was the battery causing it. Can there be something wrong with the security system causing it not to start?
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 11 Answers
  • Posted on Jul 28, 2011
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
11
Questions
0
Helped
1764
Points
35
I have the same problem few days ago, and still didn't find any solution. Can any one please help?????8
2helpful
2answers
Parked my 2000 Ford Mustang at the store. Came out, unlocked & got in, put my key in the ignition. It turned all the way over with no resistance, but my car didn't start. No noise, no nothing. The gauges...
Could be a bad battery or your battery cables could be loose or corroded so there is little power getting to the starter.Check all battery cables at both ends and might even have to take the cables off the battery and clean the connections hook up to the battery.
Our 2000 Mustang continually needs to be battery jumped. Took to shop, they said not battery or starter. They said it's Ford car alarm that is draining battery. Now what?? How do I disconnect
If the shop could find the problem, why
can they not resolve it ?
Need a different shop, if there is such
a place these days, that can actually
fix something
My 1999 ford mustang is revving rpms while I'm at a stop light. What could be causing this? It makes the car want to jump forward. It has done this 3-4 times in the past 3 weeks.
is your check engine light on or has it been on recently? sounds like your cpu is adjusting fuel mixtures if you have had your battery unplugged for a good amount of time youre ecu/cpu does this. Has happened to me quite a few times. it should stop after it does what it does, i would say a week max.
2answers
87 mustang gt-battery good, alternator is good. Doesnt start all the time, have to jump it. What could be the problem
most likely if you have to jump it then your battery is not good or your baterry connections arent good or ground from battery to chassis isnt good or combination of either... Good Luck
2006 Ford Mustang GT 4.6 liter can jump off
its most likey your altenator there =s no charge going to the batt
1helpful
98 sentra not starting.
check fuses under the hood main fuse
2helpful
2000 Ford Ranger
TEST B: BATTERY VOLTAGE OUT OF RANGE - DTC B1676
1. Check if vehicle has been jump started within past 2 weeks. If vehicle has been jump started, ABS is
okay. If vehicle has not been jump started, go to next step.
2. Using DVOM, measure voltage between positive and negative battery terminals. If voltage is 9-19 volts,
go to next step. If voltage is not 9-19 volts, diagnose charging system. See appropriate GENERATORS
article in STARTING & CHARGING SYSTEMS.
3. Turn ignition off. Disconnect 25-pin ABS control module. Install EEC-IV 60-pin Breakout Box (014-
00322). Turn ignition on. Measure voltage between breakout box terminal No. 20 and ground. If voltage
is more than 10 volts, go to next step. If voltage is less than 10 volts, repair Light Blue/Pink wire between
ABS control module and instrument panel fuse panel.
4. Turn ignition off. Measure voltage between breakout box terminal No. 25 and ground. If voltage is
greater than 10 volts, go to next step. If voltage is less than 10 volts, repair Red wire between ABS
control module and power distribution box/engine compartment fuse box.
5. Measure voltage between breakout box terminal No. 9 and ground. If voltage is greater than 10 volts, go
to next step. If voltage is less than 10 volts, repair Yellow/Light Green wire between ABS control module
6. Measure resistance between breakout box terminal No. 8 and ground. Also, measure resistance between
breakout box terminal No. 24 and ground. If both resistance measurements are less than 5 ohms, replace
ABS control module and repeat self-test. If either resistance measurement is greater than 5 ohms, repair
suspect Black wire between ABS control module and ground distribution.
NOTE: DTC B1676 will set if vehicle has been jump started.
2000 Ford Ranger
2000-01 BRAKES Anti-Lock - 4WAL - Explorer, Ranger & Mountaineer
Top Ford Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Ford Expert? Answer questions, earn points and help others
