In working with consumer electronics a lot of years, the pickup, mechanism or CD section is not always at fault but people that are trying to work on their own equipment make assumptions that may not be correct. If you put in a new CD player then the other issues as with all wave soldered equipment can be bad solder joints and even bad solder at joints where the connectors are as these get a lot of activity in a repair. Look at the PCB well. I have fixed a lot of equipment by resoldering bad or broken joints. Check around power transistors and those larger drive transistors for these broken joints.
Try this: 1. While holding "Title", Press Stop to enter what Denon calls "presetting" mode. 2. Press Track Search Reverse or Track Search Forward until you get to 20, which is the presetting mode for Single/Continuous Play. 3. Press Play to toggle between Continuous and Single Play. 4. Press Stop to exit Presetting Mode. Hope this works! I just finished a belabored job without Single Play on this unit. I have been searching for the answer too. I don't have access to the deck to try it, but I think this will do the job.
