Question about Maytag M7DH45B2A Dehumidifier
Dehumidifier runs from low to high.does not keep same fan speed.
Posted by roccomartone on
Rich Landrum
    Brigadier General:
  • 4,736 Answers
If you are operating the dehumidifier in continual mode, this is normal, based on the humidity extraction level you have the unit set on. It senses when there is humidity to remove and speeds up. When it has reached the level you have set it for, it slows down and keeps the air circulating, until it senses a need to speed up, again.
Hope this helps you. Thanks for choosing FixYa.
Posted on Jul 28, 2011
  • Rich Landrum Jul 29, 2011
    Glad I could help you. Thanks for the 3-Thumbs Up Rating.
  • fldhsufysdif Jul 30, 2011
    welcometo:http://www.fullmalls.com
    The website wholesale for many kinds of fashion shoes, like the nike,jordan,prada,****, also including the jeans,shirts,bags,hat and the decorations. All the products are free shipping, and the the price is competitive, and also can accept the paypal payment.,after the payment, can ship within short time.
    free shippingcompetitive priceany size availableaccept the paypal
    =====http://www.fullmalls.com =====
    jordan shoes $32nike shox $32Christan Audigier bikini $23
    Ed Hardy Bikini $23Smful short_t-shirt_woman $15ed hardy short_tank_woman $16Sandal $32christian loubo utin $80
    Sunglass $15
    COACH_Necklace $27handbag $33AF tank woman
    $17puma slipper woman $30
Dehumidifier won't shut off runs continually
the fan runs or the compressor and fan run ? the reason i ask is all the new units now have a air circulation mode and fan keeps going allthe time run on low speed to avoid noise
Oct 02, 2014 | Dehumidifiers
Why does the fan run non stop? the compressor runs and shuts off but the fan just runs on high and low. I have 3 other dehumidifiers that the fan runs only when the compressor runs...why doesnt the...
Depending on the time sequence you have this unit set to run, Fredrich's are designed so that the fan runs almost constantly, to keep the air moving. When it senses a rise in humidity above the level you have it set on, the compressor turns ON and runs until the level of humidity is lowered. This is especially true, if you are operating this unit in continual mode.
Hope this helps you and thanks for choosing FixYa.
Aug 14, 2011 | Friedrich D50C Dehumidifier
My Daby dehumidifier will sometimes have coade P1 show up on LED readout and also go to high fan. I have it in basement and set at 50% and low fan. What is the problem? I have to disconnect and reconnect...
don't know what the P1 code means, but maybe your demand of 50% and low fan is not able to be achieved so the unit will increase the CFMs (high speed on fan) to try and reach the 50% humidity level you are asking it to do within a certain time period.
Jun 11, 2011 | Danby DDR607EE Dehumidifier
My dehumidifier is (6) years old. Only used (4) months a year in this climate. Plugged it in this year for the first time and the fan is blowing on high without the power button on. Fan speed control with...
My guess is something got into the controls and has shorted the power to the fan. Take panels off of the unit and vacuum, and wipe or brush, with soft brush, as much as you can. Do not use any liquids in cleaning. Hope this works for you.
Jun 01, 2011 | Maytag M7DH65B2A Dehumidifier
My Kenmore dehumidifier has stopped drawing water from the air to the collection receptical. Fan still runs at high and low speeds.
A couple of things may be happening: The humidity extraction level may be set to high and it can't extract any humidity at that level. Reset/Lower it to 35%. The fans on most dehumidifiers run almost constantly (designed that way) so that it keeps moving the air around. If the sensor picks up a higher humidity level than what it's set to maintain, the compressor will turn ON. This is particularly true, if you operate the unit in continual mode, rather than a timed mode. Also, a dirty or clogged air intake filter, hinders the units ability to remove humidity/moisture.
In addition, operating the unit is ambient air temperature of between 40 & 60 degrees F, causes the unit to struggle to dehumidify the air and the fan to run continuously. Obstructing the air flow around the unit, will also cause it to not function as it should. Maintain a minimum of 12" of free air space around all 4 sides of the unit.
Hope this helps you troubleshoot and solve the problem. Please let me know.
May 28, 2011 | Kenmore Dehumidifiers
My GE 50 pt humidifier works great - except it will not let me set the fan speed to low or medium - it runs on high all the time. I am SUPPOSED to be able to set fan to low.... HELP IT"S TOO LOUD ON...
It sounds to me like you have a defective switch. I would recommend that you contact a G.E. dealer with the model and serial number and describe your problem.I can't find the right file right now but I believe thatthis switch is about twenty dollars.Thank you.
May 14, 2011 | GE AHG40LA Dehumidifier
Why does my unit display lo when i try to turn it in
If you're referring to the small light, just above the fan blade icon on the control panel ... that's the fan speed. It reverts back to LOW each time the unit is manually turned OFF. I that's the one you were referring to, it's nothing to worry about. If you want to raise the fan speed to HIGH, press the fan icon.
Hope this helped to answer your question, Christina. Please let me know.
May 04, 2011 | Haier DE45EAL Dehumidifier
New dehumidifier runs very hot...back of unit is extremely hot to the touch, and the space around it becomes uncomfortable to live in. With hot summers like this one (and maybe future ones?) we don't need...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Sounds like the compressor is toast...
There can be many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Aug 23, 2010 | Haier 45-Pint Dehumidifier
Maytag M7DH45B2A Dehumidifier Logo
222 people viewed this question
Top Maytag Dehumidifiers Experts
Marvin
Marvin
Paul Carew
ray gallant
Are you a Maytag Dehumidifier Expert? Answer questions, earn points and help others
