Question about Bosch Axxis+ WFR 2460 Front Load Washer
My Bosch Maxx (probably about 7 yrs old) was working perfectly till I opened the filter compartment (bottom right) to check it wasn't blocked. It wasn't. Put it back. Next time used machine there was a really loud noise while pumping water out and spinning. I opened filter again at end of wash to see if I hadn't replaced properly and could feel some wire like an uncoiled spring in outlet. Also the machine wasn't on the level having been pulled out for something else and not been put back properly. I pushed it back and have just tried it again - this time water pouring straight out of filter compartment at bottom, bypassing the drum. Can you help?
Posted by smotteram on
How-2-Repair.com
  • Bosch Master
  • 744 Answers
Bosch Maxx This video will show you how to change the pump washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Posted on Aug 05, 2013
5 Related Answers
Anonymous
SOURCE: Bosch Maxx WFL2260
Here are the symptoms: - Wash cycle seems ok but can not be sure. When complete the rinse commences but am unaware what happens next. This is what I have done Started washing clothes and waited for cycle to end(!) or problems start. Switched off and set program knob to rinse. At this point I select spin and after a while the water starts to empty. When a sufficient amount has emptied I stop the spin (no spinning has began), and set the knob to wash again. This now allows clean water to rinse the clothes and when I think it has rinsed enough I set the knob to off then spin again until all the water has emptied. When the drum is empty the spin cycle should continue but does not. What happens is there is a clunking sound and the activity light goes out again, when it comes back on the machine tries to start the spin again and the sequence is repeated.
Posted on Jul 14, 2009
Anonymous
SOURCE: Bosch Maxx 5 Washing machine will not wash, drum does not spin.
maxx5, error F63
Posted on Dec 14, 2010
Roni Davey
  • 414 Answers
SOURCE: washing machine bosch maxx 7 varioperfect
Sounds like have inadvertently activated the child lock. To deselect you need to press and hold the start button for approx 5 secs or until the key light goes out. Hope this helps, please let me know if this works or if you need further assistance.l
Posted on Nov 23, 2011
beltronic205
Gerry Harvey
  • 1481 Answers
SOURCE: Bosch Maxx - softener not dispensing into machine
It blocks very often , give it a good clean..remove soap dispenser to do so
Posted on Sep 28, 2009
tony2155
Tony Houde
  • 64 Answers
SOURCE: washing machine i not draining out. bosch maxx
two possible reasons that you dont drain pump is blocked or to much soap,
Posted on Mar 28, 2010
My dryer Bosch maxx 7 doesn't work
That is a bad motor. It is overheating and the overload is shutting it down. Check to see if there is lint buildup on the motor. If not, you will need a new motor.
Nov 04, 2012 | Dryers
Can't open filter on Bosch exxcel washer dryer
i reckon you probly had some stuff in yer pockets so don't blame the kids, anyway the filter door is probly jammed up over time with lint and stuff (should be cleaned regularly) so git a screwdriver and prise the door open and clean out all the stuff in there..All good to go again.
Nov 05, 2017 | Bosch Washing Machines
My bosch maxx stops mid cycle and the spiral icon that represents spin starts flashing. Its seems that it can not drain or spin yet the drum rotates when washing. Now i have washing stuck and i can not...
This is almost certainly a simple problem with your empty pump filter being clogged. Without knowing the model I can't be certain, but I would suggest that the empty cycle is timed and if it can't get all the water out in time because the filter is blocked and slowing the empty down, then it will fail safe and won't step on to the final spin cycle with excess water in the drum. While it's trying to get the water evacuated, you will probably see the machine doing a slow tumble for up to 8 minutes and you may also hear the empty pump running too.
You need to locate and clean the filter. Depending on the model, there is probably a round filter cap on the front of the machine at the bottom (It may be behind a small door or hidden behind a clip on panel on the bottom) Many models of this design also have a small hose to the right of the filter cap that you can pull out, remove a plug from and drain off any water in the filter before you remove the filter and get your floor wet, so take a look for this before you remove the filter and get soaked.
In the event that this doesn't work and you just want to get your washing out, you will find that turning the machine off at the wall for 20 minutes will reset it and allow you to open the door (With the power still off). IF THERE IS WATER ABOVE THE LEVEL OF THE BOTTOM OF THE DOOR, then pull the machine out and (With some help, because it's heavy!) Tip the machine backwards at about a 45 degree angle, so that the water line falls below the door before you open it.
If the above doesn
Aug 12, 2011 | Bosch Washing Machines
Error code F18 for Bosch Maxx 7 Silence washing machine
F-18 means the pump is blocked.
First checkthe filter for coins or other junks. Make sure the drain hose isn't blocked, restricted or kinked. Make sure there's no obstruction in the drain standpipe or U-bend.
If this doesn't work, might as well change the drain pump assembly. http://www.espares.co.uk/parts?k=pump
Hope it helps. ;)
Thanks for using Fixya. A 4-thumbs up for answering your question is greatly appreciated.
Jun 04, 2011 | Bosch Washing Machines
Bosch maxx 1200 has stopped draining half way through the cycle?
Probably a blocked filter.
This is located at the bottom front right of washer.
Unscrew anti-clockwise to remove and clean.
Have bucket and cloths ready!!!.
Feb 13, 2010 | Bosch Washing Machines
My Bosch Maxx 2000 WFO 2060 is leaking from the bottom. Could it be that a filter somewhere needs to be cleaned? If so where is the filter located?
The filter is usually located at the bottom right front of washer, sometimes behind a removeable cover, or a drop down flap.If you can locate it, then unscrew it anti-clockwise to remove and clean it.
There is also a possibility that there could be a hole or tear in the door seal so check the seal as well.
Hope this is of some help to you .
Dec 07, 2009 | Bosch Washing Machines
I have a Bosch Maxx condenser tumble dryer that wont work.
Have you taken the condenser itself out from the bottom of the machine? Remove the condenser from the bottom door and rotate the clamp tags which secure it in. Slide condenser out (aluminium mutli-finned box assembly) and carefully take it outside. Use a garden hose with lots of water pressure to spray each vent passage carefully to clear lint and dust away. Passages must be cleared in both directions, long ways and cross ways. Cross ways is the problem area and once you finish clearing the air ways you should see daylight through the condenser easily. Reassemble and always clear lint filter in the door /drum area.
Good luck.
Sam
Sep 02, 2009 | Bosch Dryers
Bosch Maxx will not drain or spin. Cannot remove the filter cap located at front bottom right hand side to see if any blockage. Grrr....
Assuming you have tried to turn it anti-clockwise to remove filter, then something is probably stuck in filter, try pushing and pulling alternatively, and unscrewing at same time, if this does not work, then you are going to have to remove the complete pump with filter, and take it apart.
Please rate my solution.
Thanks.
Aug 26, 2009 | Washing Machines
Bosch KGU44120 frost free fridge freezer (6 years old) generates ice on floor of freezer compartment within a couple of hours. Maintains -20C temperature no problem.
drain is blocked in freezer. take back panel off inside the freezer and you will probably find that the bottom is covered with ice. melt off with a hairdryer and hot water till water flows freely down the drain. needs a bit of patience
Jul 04, 2008 | Bosch Refrigerators
Bosch Maxx WFL2860 filter leaking
unplug the power before you do something leak first check and then clean filter, replace some hose available in appliance center.
Jan 03, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Axxis+ WFR 2460 Front Load Washer Logo
298 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
