Neff 24 in. S5453X1 Built-in Dishwasher Logo
Posted on Jul 28, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Water keeps running and does not appear to get hot. Cycle does not complete
Sam
Level 3:
  • Neff Master 3,247 Answers
  • Posted on Jul 28, 2011
Sam
Neff Master
Level 3:
Answers
3247
Questions
0
Helped
1305504
Points
10378
The heater in the dishwasher might be faulty. Try running a quick cycle which does not heat water and check if the problem goes away.
The heater element can be found here.
tip
Keeping the coffee maker clean
Coffee makers of all types depend on a tube to convey the hot water to the brewing basket. Filling the reservoir with WHITE vinegar and running a complete brewing cycle, then running a cycle or two of clear water (to rinse) will keep the insides of the coffee maker clean, and the tube clear of limescale or other accumulated impurities.
After washing it appears white on all the vessels. It started happening recently. how to fix it?
Hi
White film deposits are observed if water is hard or when you are using more detergent than needed, try filling detergent cup half way. Try using white vinegar after the wash cycle is complete, run a complete cycle. Also turn down the heat on the hot water fed to the dishwasher. Try using water softener for better results.
You can also add vinegar in the final rinse cycle.
Hope this helps... Please post back if more information is required.
Daniel
Why do i keep getting deposits left in the cups and glasses on top shelf of my dishwasher ?
Hi
Daniel
Nov 20, 2010 • Dishwashers
The dished appear to have a milky film on them after washed. We we use rince aid but it is not working. How de we get them sparkeling clean ?
Hi
Daniel
2helpful
2answers
Error message only prior to the rinse cycle,not filling correctl
The cold water solenoid valve seems to have failed on you. They're easy to replace and can be purchased at any appliance parts company
Jun 15, 2009 • GE Dryers
Running time of dishwasher
he cycles times are too long If your dishwasher's cycle times are too long, check these:
Water pre-heating
Cycle not completing
Water pre-heating Your dishwasher may pre-heat the water. If so, and if the water entering the dishwasher is cool, the heater may take up to half an hour to heat the water.
To avoid the wait, increase the incoming water temperature before turning on the dishwasher. Do that by running the kitchen sink faucet until the water runs hot. Or increase the temperature of the hot water to the entire house at the hot water heater.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
Cycle not completing See "The cycle doesn't complete" section.
The cycle doesn't complete If the cycle doesn't complete, check these:
Water-heating cycle
Timer
Water-heating cycle Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows:
  • On some units, the pause is timed and the unit continues after the allotted time.
  • On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too.
Timer Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
2helpful
Dishwasher runs for a long time
Water pre-heating
Water pre-heating Yourdishwasher may pre-heat the water. If so, and if the water entering thedishwasher is cool, the heater may take up to half an hour to heat thewater.
To avoid the wait, increase the incoming watertemperature before turning on the dishwasher. Do that by running thekitchen sink faucet until the water runs hot. Or increase thetemperature of the hot water to the entire house at the hot waterheater.
Won't Stop
Water pre-heating
Water pre-heating
Water
you need a cold or hot water valve. one of them is not closing all the way after the cycle is done. turn off cold water at wall, if no water appears you know its the cold water valve. if water does apear you know its the hot water valve
Top Neff Dishwashers Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Tracy
Are you a Neff Dishwasher Expert? Answer questions, earn points and help others
