Hey there, Normally simply pressing a random key on your keyboard or moving your mouse should wake it up, if it doesn't though I think the easiest way to solve this is to simply turn off the sleep mode after x amount of time.
If you have windows 7, press the start button and type in "power options", go ahead and open power options and there you will be able to set the time it takes before your PC shuts down, and you can also set it to never.
If you still wish to use this feature but just want to be able to it's a bit tricky and it won't even work for all PCs but if the keyboard waking isn't working, then it's probably because your pc does have this feature. When your PC is off, boot it up again and enter the bios by pressing F10 i believe it is for HP.
And somewhere you should be able to set which devices are allowed to wake up your computer, all devices are probably disabled now, so go ahead and enable the keyboard to wake up your computer. Now save and exit, and the next time your PC goes to sleep mode you should be able to wake it up by pressing a key on your keyboard.
I hope I was able to assist. If I was, please don't forget to rate this solution.
