Tamron SP AF 17-50mm f/2.8 XR Di II LD (IF) Lens Logo
Posted on Aug 07, 2017
I have a tamron XR Di 2 SP 17-50 mm lens on a Canon 7d body. In the picture mode I get the error 01, faulty communication between lens and camera. In the movie mode everthing works normal. Any other lens (Sigma, Canon) works fine in picture mode. I cleant the contactpoints of lens and camera, I did several hard resets on the camera but the problem persists. Any sggestions? sincerely, Maarten
1 Related Answer
elix0411
Jose Cada
  • 3530 Answers
  • Posted on Jun 06, 2011
SOURCE: Error 99 with a Canon
Welcome to Fixya
Err 99 could mean several different things, such as... Memory Card, Lens or Lens contacts....
Here's what you can try:
Remove the memory card an enable "shooting with out memory card" and see if you still get the error. If it works your memory card is bad. Try another lens if you can. Clean the lens contacts with a pencil eraser (be careful not to get eraser dust in the camera body or in the lens). Worst case scenario is, Err 99 could be related to the shutter failing which would mean a trip to Canon.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
1helpful
Tamron 90mm macro lens communications error
Hi this is problem of innner flex damaged so just replace this flex and its done
If you want any more help
[email protected]
Pic is attach only for your knowladge its not for your lens
Its like this
I have the tamron 18-200 mm XR Di-II if macro lens. The camera displays the error Err 01 Communication between the camera & lens is faulty. Clean the lens contacts. This error...
So, have you cleaned the contacts as you were advised? You do this by removing the lens and cleaning the contacts on the camera body and on the lens where they meet with a cotton swab lightly dampened with rubbing alcohol.
May 19, 2011 • Cameras
Error 99 with a Canon 300D (original rebel) and Tamron XR Di II 18 to 200 mm lens. Occurs when lens is zoomed out. Does not happen with other lenses (Canon 18-55 kit, Canon 75-300). Cleaning contacts on...
Welcome to Fixya
1helpful
I have a tamron 70-300mm i had a canon 1000d and the lens worked pefectly fine with it but nw i hav purchased canon 550d and when i conect my tamron lens with it , it shows an error 01 please assist me
This is the kind of error which you always risk these days in buying lenses which are not from your camera manufacturer. Error 01 simply means that the camera cannot communicate with the lens. Canon's protocols are not open standards and third party manufacturers have to reverse engineer to produce something which works. As they're working in the dark, they cannot always arrive at a solution which makes all models suit all Canon bodies.
You have two possible solutions:-
Visually inspect the contacts on the lens and the camera body and if they're anything other than clean and bright then use a clean pencil eraser on them. Be very, very, careful not to let any of the rubber crumbs into the lens or the camera body.
If that fails, visit the Tamron website to see whether the lens can be returned to be updated for other bodies. if it can't then sell it and buy a later Tamron model or better still a Canon one. They may cost more, but the results are better and their resale value is much higher.
Error 01 tamron lens 70-300 mm af 4-5.6 with canon dslr 450d
Error 01 means that communication between camera and lens is faulty. Try to clean lens contacts.
2answers
Tamron lens and canon speedlite compatibility
Your question is posted under a Nikon version of this lens. I assume you are talking about using the Canon EOS mount version.
The short answer is: Yes
Top Tamron Cameras Experts
Ngoro
ADMIN Andrew
ADMIN Andrew
Are you a Tamron Camera Expert? Answer questions, earn points and help others
