UTStarcom CDM7025 Cellular Phone Logo
Posted on Jul 27, 2011
Desbroquear fdn backflip - UTStarcom CDM7025 Cellular Phone
My phone is Samsung Galaxy J4 Plus. I accidentally on the fixed dialling number but I cannot turn off now because my PUK 2 was permanently blocked as I tried too many PIN codes.
Is it stolen? Bought in a pub? Found in the road? How can you not know your PIN Code?
PUK Codes can only be supplied by the Telco that owns the phone. There is NO OTHER WAY. Locked with a 128 bit RSA Encryption Code.
All about PUK Codes
https://www.fixya.com/support/r26056685-phone_asking_puk_code
Outgoing calls are restricted by FDN mode - YouTube
https://www.youtube.com > watch
PREVIEW
0:52 Outgoing calls are restricted by FDN mode on samsung galaxy mobile , how to disable /enable FDN mode.
YouTube · Ratan Mulewa · May 21, 2017
1helpful
2answers
Hoe I do disable outgoing call FDN restricted
Fixed Dial Number (FDN), allows you to restrict outgoing calls to a limited set of phone numbers on your Samsung Galaxy Note 2.
How to enable FDN on Samsung Galaxy Note 2
  • From the Home screen, tap Phone icon.
  • Press Menu key and then tap Call settings > Additional settings > Fixed Dialing Numbers.
  • Tap Disable FDN.
  • At the prompt, enter your PIN2 code and tap OK.
1helpful
2answers
Fdn motorola backflip
www.motorola.com/.../BACKFLIP.../BACKFLIP_UG_ATT_68014710001A.pdf
thats the manual and will help you enable the fdn or disable it
rate me if i helped
Dec 05, 2010 • Cell Phones
40helpful
6answers
Error message "Number FDN restricted"
I can receive the call from outsider but wont be able to make call to outsider. When I trying to dial out to somebody it says "number FDN restricted" Please help.
How to off the FDN mode of my cellphone
i have a sumsung sgh-s730m and to turn off the fdn i opened the phone to the key pad them hit the little button with the three lines on the actual phone went into settings and turned off the fdn fixed diailing numbers by clicking on managing it and then entered my pin2 number and disabled it hope it helps
1helpful
WHATS A FDN?
FDN (fixed dialing mode) is the setting where you can't dial a number that's not in your sim card data. It is supposed to be used as a security measure when you're away from your phone and don't want someone to use it to make an unauthorized call -- unless the number is in your sim card you won't be able to make the call.
If this helps please vote.... I need the ratings. :)
Modifying FDN list of LG phone
how ca i find my FDN pincode if my phone is new never used I just baought
Blackberry 7100g
About fixed dialing
If you enable fixed dialing number (FDN) mode, your device only makes calls to contacts on your FDN list. Your device can dial emergency numbers in FDN mode, even if the numbers are not in the FDN list. If your service provider plan includes SMS, you can also send SMS messages to contacts on your FDN list
so if you have this enabled chances are you have to turn it off.
this is how you turn it on so you should be able to use it as a guide to turn it off.
Turn on fixed dialing
1. In the phone options, click FDN Phone List.
2. Click the trackwheel.
3. Click Enable FDN mode.
4. Type the PIN2 code provided by your service provider.
5. Click the trackwheel.
or if you wanna keep it on and add friends to the fdn
Add contacts to the FDN list
3. Click New.
6. Type a name and a phone number.
7. Click the trackwheel.
8. Click Save.
and finally some shortcut keys:
To open the phone, press the Send key.
To end a call, press the End key.
To call a selected contact or phone number, press the Send key. To call a speed dial number, hold the assigned key.
To add an extension to a phone number, press the X key. Type the extension number.
To call your voice mail access number, hold 1.
To type a letter in a number field, hold the Alt key.
To type the first letter on a key, press the letter key once.
To type the second letter on a key, press the letter key twice.
To turn on or turn off mute using the Mute button, press the Mute button.
To turn on or turn off mute using the keypad, press the exclamation point (!) key.
To turn speakerphone on and off during a call, press the period (.) key.
To change the volume during a call, roll the trackwheel.
3helpful
Top UTStarcom Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
 Mikey
Mikey
Are you an UTStarcom Cell Phone Expert? Answer questions, earn points and help others
