Question about Nikon COOLPIX S10 Digital Camera
Nikon CoolPix S10 -- display shows a blinking red hand. I don't know what is wrong. Can you help? Thanks, Leslie
Posted by leslie_angie on
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Nikon Master
  • 102,366 Answers
Set the date and time by using the "Date" command in the Setup menu.
Posted on Jul 27, 2011
My Nikon Coolpix s230 flash won't work. It just blinks red in the lower right hand corner. I've tried all the settings and they all won't flash.
If there is a problem with the flash itself or the mainboard connection to the flash it will not charge. If the flash won't charge then it won't go off when you take a picture. The only way to fix the problem is to replace the flash with a good used one and see if that fixes it. If not, then you need to replace the mainboard. Good used parts can usually be found online for cheap; that auction website doesn't pay me to type their name, so I don't, sorry. Hope this helps!
Thomas Drayton
Owner, www.darntoothysam.com
Affordable Digital Camera Repair
Jul 24, 2011 | Nikon COOLPIX S230 Digital Camera
Turning auto flash off nikon coolpix p1
I have problem with my camera nikon coolfix L15, the flash light can't on and the display can not show the object I need help to solve this problem any body knows can tell me to [email protected] for your help I say many thanks
Apr 29, 2011 | Nikon Coolpix P1 Digital Camera
Red hand blinks on screen upper right side. how do i deleet this problem. nikon coolpix 7500.
The red hand icon flashing shows that the camera is using a slow shutter speed, and is a warning to be careful to hold the camera steady.
You could put the flash in auto mode and it will fire when the light is low.
Jul 16, 2009 | Nikon Cameras
THE LCD DISPLAY IS BLANK
I had an older nikon and it gave me that same problem, I was told that it was the internal lenses getting stuck. If that is what your problem is, then take the camera while it is off and slam it against the palm of your hand, I know it sounds pretty weird, and I was nervous to try it, but after a couple of hard hits to the hand, it turned on and stayed on perfectly.
Mar 04, 2009 | Nikon Coolpix S550 10 Megapixel Digital...
Auto focus
you push the button half way down (sounds crazy) but that is when you are letting the camera know you want it to focus and when it turns green push the button the rest of the way down
Jan 20, 2009 | Nikon COOLPIX P80 Digital Camera
Nikkon coolpix l10 won't snap picture
hi there
just an idea the big multi button with the ok in the middle
press the 3 o'clock bit with the mountain symbol on it (while in camera mode) it should say auto but if it doesn't use the 12 o'clock and 6 o'clock keys to select auto then press ok in the middle.
hope this helps
beergut707
Oct 07, 2008 | Nikon COOLPIX L10 Digital Camera
Red hand
I got on to the Nikon website about this problem and I was advised that it was caused by the flash being switched off. I hadn't realised that the flash could be turned on or off - though itt was automatic. Anyway I restored all settings to default and the flashing red had disappeared.
Jul 14, 2008 | Nikon Coolpix S1 Digital Camera
Nikon COOLPIX S10 Digital Camera Logo
74 people viewed this question
Top Nikon Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Lee Hodgson
Lee Hodgson
Are you a Nikon Camera Expert? Answer questions, earn points and help others
