Cell Phones Logo
Posted on Jul 27, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
We have a DECT 6 system with a base unit and five satellites. Suddenly the satellite phones don't work, but they are alive (with no dial tone and don't ring) and show a message "out of range". The central base unit still operates normally. The satellite bases seem to be charging, and bringing the extension phones near the base unit doesn't help. Can you advise what is wrong and how to correct this?
Anonymous
Level 3:
President:
  • Master 3,278 Answers
  • Posted on Jul 27, 2011
Anonymous
Master
Level 3:
President:
Answers
3278
Questions
0
Helped
785186
Points
9440
Hello.
From FixYa Support:
- unplug base unit for 15 seconds
- press "PROGRAM" button on handset
- from menu, select "HANDSET SETUP"
- from menu, select "REGISTRATION"
- handset display will prompt you to press and hold PAGE button on base unit for 5 seconds, then press "PROGRAM" button on handset
Perform steps for each handset. You may need to plug base unit and unplug for each handset.
Hope this helps.
I not have manual for Uniden dect 6 cordless phone on my phone I can't get any dial tone,I think I pressed a button on the phone either mute, intercom or redial, how to reset phone
If you have no dial tone the problem is most likely the base station has failed, nothing you can do will kill the dial tone (no button you pushed etc.) except a failed base station.
Phone not working
Hi Pam,
Try these..1...remove your telephone line from base unit and fix it into a working land phone and check whether is it having normal dial tone.If it's having engage tone(beep beep...)remove paralleled phones and re connect to cordless base unit.
2.If line is ok (normal dial tone with full volume) & still display indicates line is busy, your main base unit must be having faulty components inside.Commonly these defects happen in thundering or surges through telephone lines.You have to take full set to a repair shop.
Rana.
2helpful
I have 2 problems. 1. The orange message light will not stop flashing no matter what I do. 2. Some how the system was switched from touch tone to dial tone. I can't seem to that switched either.
Resetting the voice message waiting indicator
When you receive a new voice mail message, the new message LED on the top of the handset flashes. In the event your message waiting light gets out of sync with your phone company's
voice messaging system, you can manually reset it back to the "No messages waiting" state.
1. Press and hold FiND on the base for five seconds.
Note: The handsets connected to the base will start to beep, however, keep pressing for five seconds.
2. A beep sounds and the message alert tone is reset.
Changing the dial mode
Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most base networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you will need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, please follow the steps below to modify your phone's settings:
1. Press MENU/SELECT.
2. Select the Global Setup menu, and then the Dial Mode submenu.
3. Scroll to highlight Pulse.
4. Press MENU/SELECT. You will hear a confirmation tone.
If you ever need to change the dial mode back to tone dialing, follow the same procedure, but select Tone in step 3.
Finally for future ease of use, here is a link to the user manual were I copied the above information from:
http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/DECT1580-3om.pdf
I bought five Panasonic KX-T7730X phones. The business i work for has a Panasonic KX-TD1232 system. I unpack all phones and tried it on different extensions and won't work. there isn't ant pulse....
A TD system is a DIGITAL phone system and the 7730 phones are ANALOG. I don't know what X means, but I guess they're not from the US :-). Anyway, the ANALOG phones need 4 wires to work, instead of the 2 that the digital phones have. If your installer was lazy and didn't cross-connect 4 wires at the frame or put in 4 bridge clips on each jumper, then you don't have a voice path. Or, XDP is turned on and you'll have a bit of a problem.
If you have an IM and a PM for the TD system, you can find the wiring diagram and the instructions to read the XDP status. Quick answer is the first 2 of every 3 pairs will run to your phone. If you start with a digital phone in the port first, turn on XDP and plug a single line set into the XDP port, you will get dial tone (may have to dial 390 or 391 to enable/disable the XDP twinning) and that dial done will be different from the digital phone. If you don't get dial tone, your first pair wiring is missing. Fix that, turn off XDP and you 77xx series phone will now work in the port.
Carl
3helpful
No dial tone. Base will ring. Handset has no
Check the Battery on the Handset. remove the pwr frm the base unit n connect aft 30 sec. aft this if it still says the same msg, then the handset needs to be replaced.
Top Uniden Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you an Uniden Cell Phone Expert? Answer questions, earn points and help others
