Question about Porter Cable Cable Premium Pressure Washer PCH2425
Water stopped coming out while using it. viewing port on right side shows a red dot in center.
Posted by mtacupunctur on
Fred Yearian
  • Porter Cable Master
  • 5,603 Answers
The most common cause of this is the pressure regulating spool valve sticks in the bore. As the pressure builds with the wand closed, the spool moves against a spring to block additional water from entering. When wand is triggered, pressure drops and more water is admitted. Remove the spool and clean the bore with crocus cloth on a dowel rod. Replace the O Rings on the spool and lube with a bit of plumber's grease and re-assemble. Often you can get a kit of O Rings for the washer or you can get EXACT replacements at a supplier... they MUST be the exact size as the originals.
Posted on Jul 27, 2011
We just set up our telescope and can't see anything. We do have the cover off, have used all the eye pieces but it's dark. Kinda feel like a dope but obviously we're missing something. ...
Start by using it during the day pointing at a nearby object (100yds or so) Start by sighting along the axis of the scope. Use the lowest power (highest number in mm) eyepiece. (BTW the eyepiece is in the front of the scope where the light comes in and this will be the part of the scope that is closest to the object) Once you can see the object, move to the higher power eyepiece to center on the object and then align the led pointer so the red dot is also centered on the object.
After this initial alignment, pick a night that the moon is out and try it.
Note: The 114 shows correct image (right side up and left to right) unlike most other scopes. It is a nice telescope/ ( I have the 130mm)
Jul 03, 2011 | Celestron AstroMaster 114EQ (100 x 114mm)...
Good morning (in Brazil). I cant find WHERE to place the battery ON red dot finderscope; should it be placed where the plastic insulator is? I cant find a case, or whatever it is.
Most red dot finders use small watch style batteries. Look for something that slides out of the red dot finder and or a port in the side or the bottom.
Jun 06, 2011 | Bushnell NorthStar 78-8846 (675 x 114mm)...
Red dot seems to disappear when you move the sight right to left or up and down.
You are simply moving the dot out of the field of view.
The Aimpoint is set up to allow you to hit now matter where in the field of view the dot appears. High, low, right, left, it doesn't matter. If you can place the dot on target, your bullet will hit where the dot appears. Too much angle away from the center will move the dot out of your field of view however, This is apparently what is happening to you.
Oct 10, 2010 | Aimpoint 10338 CompML2 4 MOA
Red line on screen
Are you able to view the same Red lines even in the BIOS window? If yes, this may be LCD issue too.. The LCD will show small red dots which are called Dead Pixels. If the Red lines and dots are more, then it is better to contact the Service Center
Jul 03, 2010 | HP Pavilion dv7-1132nr Notebook PC
My Ipod touch will only turn on when plugged into the wall or the car charger. When connected to the computer the apple logo flashes on and off but will not do anything.
do this...
While connected to a power source, try to reset the iPod touch. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until either the Apple logo or battery symbol appears. If the battery symbol appears, continue to charge iPod touch until it is fully charged. if still doesnt power on try this.. Use the following steps to place your device into recovery mode. If the device is already in recovery mode, you can proceed immediately to step 6.
  1. Disconnect the USB cable from the iPhone or iPod touch, but leave the other end of the cable connected to your computer's USB port.
  2. Turn off the device: Press and hold the Sleep/Wake button for a few seconds until the red slider appears, then slide the slider. Wait for the the iPhone or iPod touch to turn off.
    • If you cannot turn off the device using the slider, press and hold the Sleep/Wake and Home buttons at the same time. When the device turns off, release the Sleep/Wake and Home buttons.
  3. While pressing and holding the Home button, reconnect the USB cable to iPhone. When you reconnect the USB cable to iPhone, the device should power on.
    Note: If you see the screen pictured below, let the device charge for at least ten minutes to ensure the battery has some charge and then start with step 2 again.ht1808_01.jpg
  4. Continue holding the Home button until you see the "Connect to iTunes" screen. When this screen appears you can release the Home button:
  5. If necessary, open iTunes. You should see the following "recovery mode" alert:
  6. Use iTunes to restore the device.
also maybe your unit have been in contact with liquid You can tell if the headphone-jack Liquid Contact Indicator has been triggered by looking directly down into the headphone jack. Use a lighted magnifying glass or angle the iPhone or iPod so light shines down into the headphone jack. At the base of the headphone jack, you should see what is normally a white or silver-colored dot. The dot will become full or half red or pink when the dot has come in contact with water or a liquid containing water. To view the dock-connector indicator on iPhone 3G or iPhone 3GS, use a lighted magnifying glass and hold the device so that you can view the center bottom of the dock-connector housing. A full or partial red dot will appear if the indicator has been triggered.
a feedback would be much appreciated
Jun 06, 2010 | Apple iPod touch Second Gen (8 GB,...
I have a side by side Fridiaire FRS6R5ESB. I came
I solved my own problem. Just realized the red & green dots are not lights
The only LIGHT is the top signal light marked " water filter." which is green
when filter is ok & turns red when filter needs changing. The red & green
dots are not lights but are indicators for the water filter light. Red dot meaning
"change filter" and the Green dot means "filter ok"
May 01, 2009 | Frigidaire FRS6R5EMB Side by Side...
I an trying to use the voice recorder on my iHP-120
Press and hold button on left side with red dot (record)... You will see "stand by"...  Press the lowest button on right side (A-B) over and over until "source" is "int Mic"... when you are ready to record, press the left button w/ the red dot short and quick... recording will begin.  When youre ready to stop recording, press middle button (pic of square on it) on right side... that will stop it.
To find your recording, look in the "record" folder under "Audio"
Mar 10, 2009 | iRiver iHP-120 MP3 Player
How do you use the red dot finder? and when I look throught the format eyepiece everything is upside down.... Thank you Stacie
Astronomical telescopes show all objects upside down and reversed-- this is not a problem; there is no up or down in space.
The red dot finder helps you point the telescope-- focus on a distant object and center it in the eyepiece.
Without moving the telescope -- adjust the red dot onto the object. Now you can use the finder to locate objects.
Apr 13, 2008 | Bushnell Voyager 78-9945 Telescope
Blue out of focus; casting blue "glow"
Be very carefull replacing the fluid as leaks will short stuff out and are messy.
Jun 12, 2007 | Philips Magnavox 51MP392H Rear Projection...
Porter Cable Cable Premium Pressure Washer PCH2425 Logo
117 people viewed this question
Top Porter Cable Garden Experts
JOHN LAPIER
ray gallant
Are you a Porter Cable Garden Expert? Answer questions, earn points and help others
