I have a 21inches goldstar colored tv.. it has no sound.. i already check the connections buy its all ok.. also the transistors and the IC is ok.. what is the possible cause?
Anonymous
  • 59 Answers
Solution
Step 1 : At first check your TV speaker and volume switch and more check conecting were to speaker or audio section.
Send report :[email protected]
Posted on Jul 27, 2011
1helpful
Our tv keeps changing colours to blue red and green
Your television have color problem.That symptom is cause of loose connection or cold solder in chroma section and color output driver transistor of CRT board of your television.You can fix that problem by resoldering the chroma section and crt socket section of your TV.first thing to do is open or remove the back cover of your TV,then you can see the crt board connected to picture tube.Resolder that parts,specially the color output transistor the red,green and blue driver.Resolder also the chroma section.You can see the jungle ic,thats the color ic.Make sure that there's no short circuit when soldering the PCB board.After the resoldering turn on the TV and check if color is normal.Thanks..
Im not sure if vertical output transistors is the prob, but my tv has picture only in the middle vetically, i change the capacitor and ic, but still it didnt work out, pls help.
Hello
Your assumtion is currect. But the vertical output section of this TV has no transistors at all. It is composed of an IC. Check the soldering terminal connection of this IC legs for any loose soldering first. Just resolder all the solder terminals of this IC by applying a little more solder. In most cases this will solve the fault. If not, check all the surrounding electrolytic capacitors to this IC circuit. If found suspected, replace them. Still fault perists, replace the vertical output IC with same type and number.OK.
Green light flashes for about 2 min. then tv comes on the color seems to have too much green after awhile of watching screen goes blue then black then comes back on
you can make sure all the connections that exist on the PCB Board TV is connected, if there are loose you can reconnect. Especially, usually there is often no (tin solder melts) connection between the foot pin of the components with the PCB board in a vertical section and Horizontal section.
There is another possibility it was caused by the failure of existing data in the EEPROM memory IC such as IC C2408, C2404 etc, you need to replace it
Then also you can check on the RGB Board, ensure the 3's Transistor for ( RED,GREEN and Blue ) is OK. if not you have to replace the transistor for GREEN.
In chennai free kalaignar tv sound not coming i changed sound ic an 17823a still sound not coming ples sen me the detail of this sub!!
you replaced the power amp ic before that you need investigate the condition of power ic and it's very simple when you terned on the tv set you can hear the small pop noice from the tv speaker means the power ic is good other way is just tuch the screw driver to sound if output stage you can hear the DERRR sound from the speaker
if it ok pls check the mute transistor
1helpful
3answers
My 15 year old Toshiba Televisiononly shows a narrow horizontal band in the middle of the screen. Sound OK.
Hiii fairley,
You aren't specsificly dercribe yor tv set.
For common TV horizontal problem ;i.e : White line accross the horizontal screen, horizontal band,etc..it's can solved by replacing the IC Vertical/Transistor, and olso to replace the cap nearest the IC.
For common TV Vertical Problem :i.e : White line at the center of the screen (top to bottom),Vertical band,etc...It's can cure by Replacing the Horizontal IC/Transistor,and offcurse the cap's.
Tha's what all I know....
Hope can help you to solved the problem.
Thank's
h3liax
No sound
hi first of all u should check ur transistor connections.Check your Horizontal and vertical output transistors.You should also check the horizontal and vertical yoke connections as well as your low voltage regulators.... if any of these got damaged u should purchase a new one.. but try to purchase with the help of a tv service assistant...
thank u!!!
rate me
Green tint
Check 3.58 MHz color oscillator,, little metal can near large ic,
Also check color output transistors or any loose connections in the output stage
Hyundai 14" colored tv no power
if the final flyback is ok ,then check the driver transistor and the voltage in his collector .Probably the flyback transformer is ok.please reply.
Sony WEGA TV Red color wont display at all.
as other color are ok(blue&green)& no red colour.please check as follows. 1 check supply to red video transistor. 2 check for loose crt base. 3 check for loose connector 4 check components related to red video ckt.& cathode ckt. 5 check for red signal is coming to red video ckt. 6 check red cathoe voltage. 7 signal processor ic.
2answers
Zenith 25in. System 3 TV. Intermittent problem with color going all red??
It certainly sounds like a drive problem in the set. It could be a bad connection on the CRT socket, a componet on the CRT driver board, a bad drive transistor, a connection between the CRT driver board and the RGB /video jungle IC, or the RGB/video jungle IC itself. If you know how to solder and or have some sort of solid state repair experience, you should be able to find this problem by simply probing around with a wooden or plastic tool tilll the problem arises. If you have no experience, there is no easy quick fix. You should find a local repair person to assist you with this repair. good luck PS Please dont forget to rate this thread.
Televison & Video Logo
Top Televison & Video Experts
Ekse
