Western Digital My Book Essential 1TB External USB 2.0 Hard Drive Logo
Question about Western Digital My Book Essential 1TB External USB 2.0 Hard Drive
Hello, Alright, here's the problem. I have a 1 TB WD My Book external hard drive with a whole lot of data on it. The thing is, when I try to access it through My Computer it says "I:\ Access is denied.". So, what I usually end up doing is going to the drop-down list at the top of the window and selecting "I:\" from there. When I do that, it opens just fine. Also, sometimes, I disconnect its USB connection and reconnect it. This brings up the Autoplay / Choose action window. When I choose "Open folder to view files", it works fine as well. I've also used Adobe Bridge to access it without any problems. When I use the Photoshop "Open file" dialogue box, there's no problem there either. My question is, what's stopping me from accessing it directly from My Computer?
Marco Avila
    Scholar:
  • 58 Answers
Typically this occurs when the permissions on your drive have been changed. Do a search on "resetting permissions" on your external hard drive that is specific to the operating system you are using. There are paid programs that can do this but don't be afraid to is a command shell window to carryout this task (this is a window where you actually type in commands with extensions like DOS in the old days). All tutorials out there will show you exactly how to open this shell window and what exactly to type in as a command. If you are not wanting to try then ask somebody you know that is computer savvy to help you out. It's only one command but once started may take sometime to complete depending on the size of your drive and how many files are on it (could take hours).
Posted on Mar 16, 2017
4 Related Answers
Anonymous
  • 64 Answers
SOURCE: Pen drive write protected
I have had the same prob and able to remove the write protected message by just unlocking the hold button. If this doesn't work there is formating software for each USB on the web. One can google and download it for free inorder to formate the USB
Posted on Aug 11, 2009
Anonymous
  • 79 Answers
SOURCE: I want to perform back ups on files and folder I choose
well if you want to back up files then first you have to consider which file is important for example your pdf files , ms office doc files and make sure you back up the my document area.
good luck.
Posted on Jan 05, 2010
Anonymous
  • 358 Answers
SOURCE: Western Digitial 320 GB Passport - Unable to access files
First of all make sure that the USB port that you are using to connect it to your PC is a USB 2.0 port, and not USB 1.0.
Also if it came with an external power, connect it to the external power before putting on your PC.
This is because the voltage supplied by USB 1.0 is lower than that of USB 2.0 and therefore might not be enough to power up your USB Drive.
After making sure about this, power up your system, and plug the external drive, then Right-Click on my computer icon, select manage, then go to Disk Management Option.
On the Disk management option Page you should see ALL the drives installed on your system, including the hidden ones, so what you will just do is, try and locate the one representing your external drive, and right click on it. then select "Change Drive letter and Paths", and give the drive any new, unique letter (i.e alphabet) different from the ones already on your system, and click on OK.
This should make your external Drive to be detected automatically.
Or in case there is a problem with the read/write head inside the hard drive.
What I would advise you to do is, unscrew the hard drive case and remove the Hard disk from the case, connect it directly to a system, not externally or through USB this time around, then get a software called NTFS DOS Professional. It is a software that works like magic when it comes to hard drive repairs.
If you know any other hard drive utility, apart from this, you can also use it. I just recommend this personally because that is what I use.
Insert it into your PC, start up your CD-ROM and let your system boot from CD-ROM.
It works through DOS, and it should be able to help you with it.
If this does not solve the problem, then I'm afraid you might need to replace the hard drive.
And if it repairs it, I would suggest that you just retrieve all your valuable files from it and don't fully rely on the hard drive again because of the hardware error it has developed. Just keep using it as a second.
If you cannot do this by yourself, just get a very good technician to do it for you instead.
Kindly keep me posted about the problem.
Hope it helps.
Goodluck.
Posted on Apr 25, 2010
Anonymous
  • 236 Answers
SOURCE: WDBAAF0010HBK-01 DRIVE ACCESS IS DENIED BY LAPTOP
you have to save the files using a computer with the same os that u origanlly and then format the drive on the windows seven computer then move the files back on to the drive
another thing to try is to try and update the drivers on your win. 7 computer
the last thing is you have lost all ur data and you should just reformat it
Posted on May 08, 2010
1 TB My Book Live Western Digital, light starts up blue then after trying to discover goes red, tried new eternet cable and still going red. Reset my router and have tried plugging hard drive right into...
I have SeaGate FreeAgent GoFlex 500GB external hard disk and it shows only 230GB. I formatted it many a time but still shows 230 Gb only..Please help me to fix the problem....
2answers
Can't read data on WD external my book hard drive
It seems that your WD hard drive is corrupted so
you are unable to access the stored files. But there is no need to worry since
it is very easy to recover data from corrupted WD partition by using Western digital partition recovery
software. Couple of days ago, even I was stuck under similar problem I tried
this software which really helped me to retrieve all my lost data.
All the best,
Linda William
Hello Folks. I have a my book essential wd 1 tb hdd.. led lights kept blinking wasnt being detected.. the info on it is valuable.. i read online and the got bright idea of taking out the sata hdd inside.....
You can get drivers here http://support.wdc.com/product/download.asp?level1=1&lang=en
But he first thing to do is determine the condition of the drive. You can check if there are problems with the drive using the free trial version of http://www.hdtune.com/
If it checks out ok then you can try to recover your data with Recuva it's free http://www.piriform.com/recuva
Or if you need data recovery help this a good choice for low cost and fast data recovery. All data recovery work is performed remotely over the Internet from a boot cd that you download and the best part is they just ask for donations if you are happy with the results: http://FreeDataRecovery.us
I plug in my WD external hard drive, i hear the chime saying the computer knows i plugged something in, but i see no icon to click on to open it. HELP! i have soooooo much information on this thing!
- try plug in a normal usb port (usb2)
- try open up the device manager, look for your WD and delete it.
then unplug and plug back.
try goto control panels->administrative tools->computer management->disk management
and see if your wd appears there. if yes, try change the drive letter assignment.
How do I disconnect (uninstall) a WD External Hard Drive from my computer? I am using a WD 3200AAK WD External Hard Drive and want to install a 1 TB WD External Hard Drive. I would like to use the old one...
External hard drives don't need any program installed on your computer to run. Your operating system Windows, Linux should handle it as soon as you plug the usb in your computer. The programs included in your WD external hard drive are tools to backup your data.
If you try to hook up your hard drive to a Windows prior to XP, maybe your computer will not handle it.
It is always safer to safely remove your drive using the green arrow icon in the lower right corner of your screen. This way, the drive is shut down properly and you minimize chances of fails when you plug it again on another computer.
Hope this helps!
1helpful
2answers
When i connect two external hard disks (each 1TB), i can't see the data of one of them
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
Note that W.D. has a "Customer Loyalty" program -- you can buy a new W.D. device, through the W.D. web-site, at a significant discount.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
Western Digital 1 TB External Hard Drive and BSOD
perhaps the new hard drive is bad western digital software is junk take it back and get seagate external w/freeagent on it
External WD my book 1T want boot on Mac or PC & makes click noise
Hello
Have a look at the link below, it should be of help.
Click HERE to navigate.
Please feel free to let me know of you have any further questions.
Kind regards
Lock123
WD 2 TB external HDD asking for password
log in from administrator see if your anti virus's or your windows fire wall is not interrupting if not solved go to run in the start menu type command "chkdsk" "netuser administrator (the password you want to give)"
Top Western Digital Computers & Internet Experts
Marvin
Marvin
Mike
Mehandi Husain ...
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
