SOURCE: Config page
You will always use a straight through. The default IP for this is 192.168.1.1 you also need to setup your PC with TCP\IP in order to log in. Go to network connections and double click on the connection for the NIC. high light internet protocol TCP\IP and click properties. then fill this in device IP 192.168.1.1 then PC IP 192.168.1.10 then 255.255.255.0 then hit OK. From there go to your browser and type http://192.168.1.1 there is no password or user name set the first time.
SOURCE: EOC-3220 connects but no internet access
What are you using for Internet connects? do you have the Access point connected to a Router. or is it connected to the Cable or DSL modem. I will need more information to complete this. If you have a router is is set to give an IP address or do you have a static IP? If it is set to give a Dynamic ip change the access point to recieve ip address from router and same with computer. If your connected directly to the Modem with the access point and you only have one IP address it will be used by the access point and not allow the computer to connect.
for more help please provide your internet (DSL, T1, CABLE) if you have router, how it provides IP, and how access point is connected to it.
SOURCE: resetting the senao eoc-3220 long range wireless access point/bridge
Start a HyperTerminal session: Click Start and then select Programs -> Accessories -> Communications -> HyperTerminal. c. Set baud rate as "38400", data bits "8", parity "none", stop bits "1", and flow control as "None". Then press "OK" to bring up the HyperTerminal window.
SOURCE: cannot browse to 192.168.1.1
TRY 192.168.1.254 IT WORK FINE FOR ME, AFTER ACCESS I RELOAD A NEW FIRMWARE, AND NOW IS 100% WORKING
SOURCE: Engenius EOC-3220+
if you have a the router's manual,there is a guide on how to do that.
but in case you dont have the manual go to the device website and get some guide.default ip varied from different manufacturer
An RS-232 null modem serial cable is required for this procedure.
1. Connect the EOC-3220 to your computer with a null modem serial cable.
2. Start a HyperTerminal session: Click Start and then select Programs -> Accessories -> Communications -> HyperTerminal.
3. After the HyperTerminal window appears:
a. Give this new connection a name. Ex: EOC-3220.
b. Select correct COM port. Ex:COM1.
4. Wait until the "#" is displayed in the HyperTerminal window.
5. Type "flash reset", then hit enter.
6. Type "reboot", then hit enter. After the device reboots, all settings will be at factory default.
