Vulcan AUW230A Heater Logo
Posted on Jul 27, 2011
My Vulcan Comfort Control ducted heating doesnt turn on. The remote displays that its working but its not. Not air comes out of the vents. One tradesman told me its the motherboard, another one told me its the gas valve that needs to be replaced. Does anyone know where l can purchase a gas valve from?
3 Related Answers
Douglas Jensen
  • 494 Answers
  • Posted on May 19, 2010
SOURCE: I purchased a house in October last year which has
Here is the link to get free downloads of the manuals you need.
http://www.bonaire.com.au/support/documentation/owner/default.aspx
Anonymous
  • Posted on Aug 17, 2010
go to www.bonaire.com.au for manual
Anonymous
  • Posted on Sep 21, 2010
SOURCE: we have a Vulcan Ultra high efficiency gas ducted heating
Gas ducted central heater won't switch on all of a sudden
Evap cooler, misplaced the vulcan touchpad controller during reno, purchased a comfort control controller, i plugged in controller, its works but nothing activates evap unit to turn on.
You can check the wiring but this looks like an incompatible controller. Here are some alternatives:
If you're looking to purchase an Evaporative Cooler Vulcan Touchpad Controller, there are several options available. Here are some places where you can buy one:
The Home Depot: You can purchase a DIAL Evaporative Cooler Digital Controller from The Home Depot for $64.48.
Gasstop: Gasstop offers a refurbished wired Bonaire Comfort Control remote that works with Bonaire and Vulcan gas central heating systems for $150.
Bonaire Heating & Cooling: Bonaire offers a range of Navigator Remote Controls for Cooler and Heater, including My Climate® Wi-Fi® for ducted evaporative cooler, ducted gas heater, or dual-cycle air conditioner.
Navigator Remote Control for Cooler and Heater (bonaire.com.au)
Bonaire comfort control not showing heat mode anymore or working
here is a link to manual. if you are renting call bld. maintenance
https://www.manualslib.com/manual/639673/Bonaire-Bonaire.html#manual
We have vulcan ducted heating. not much air comning from vents. what could be the problem
Could be simple as collapsed ducting, blocked return air filters, broken ducts, loose fan belt ( if belt driven unit)
Bonaire gas ducted heating not reaching set room temperature anymore...
has the system air filters been serviced lately
is the system circulation fab been cleaned to allow full air circulation of the system
call in a technician to check for vermin infestation preventing the system from working properly
1helpful
Bonaire vulcan comfort control
No it cant really be fitted as the evap system uses much larger duct and also in some cases people use a different type of duct that when running a gas heater threw it it tends to melt with the heat. Your best option would be to get new ducting that way you can size it correctly so you dont have air alance issues down the track.
1helpful
I have a Vulcan Bonaire ducted heating system with Comfort Control in a holiday house, installed in 2006. It was working fine last time we used it about a month ago. Today every time I try to turn the...
hi,
The heating coil itself have some problem that's why the circuit breaker clicks off by sensing over current drop. Check the heating coil and replace it.
ok
Our remote control for Vulcan Comfort Control Gas Ducted Heating is broken and we need a replacement, where can I find one as Bonair/Vulcan no longer makes this model and their spare parts business cannot...
Try Skytech Systems. They make a remote control for just about anything. And one of theirs may be adaptable to what you need. http://www.skytechsystem.com/ If you don't find what you're looking for on their website, call them and talk to Customer Service.
1helpful
I have vulcan ducted heated model no. 9255. The comfort control is reading the room temp as 35C when it is actually 11C, yes its freezing here. As the room temp is at its maximum reading the heating is not...
I replaced the batteries, even though 'battery low' message was not displayed. this fixed my problem. I wish I'd have just done that to start with.
Top Vulcan Heating & Cooling Experts
Paul Carew
ZJ Limited
ZJ Limited
john h
Are you a Vulcan Heating and Cooling Expert? Answer questions, earn points and help others
