Hello everybody.
I can`t connect ZM600(zebra) with PC by COM(rs 232). I try user guide but i can`t connect ZM600 with PC by COM.
everybody can help me.please tall me error.
Thank a lot!
Good luck for everybody
bao4: You must configure with the same serial port parameters of the printer and the pc. Is the cable you are using correct?
Roberto Martinez
[email protected]
If the problem is on the right side , try adjusting the head pressure adjustment knob on the top right side. You can adjust with a flat blade screw driver.
I am not a Linux Guru but is the printer the prints go to the Default printer on the server you attach to? if so that will be the problem. You need to map the printer back to you local laptop. If this was a Windows Terminal Server environment this is done automatically when using RDP. it will be similar to the way you map your local Floppy or CD.
The Zebra Stripe S500 has a RS-232 SERIAL interface using a DB-25 connector . You'll need a USB to SERIAL converter, not parallel. Be sure that the baud rate and data/stop bits are set the same on the printer and interface converter. Generally speaking, use the fastest setting possible (19200 baud) unless you encounter problems.
