Question about Canon CanoScan 3000ex Flatbed Scanner
I need driver canonscan for windows 7 64 bit, on website canon support & driver not available. why?
Posted by masbherg on
Anonymous
    New Friend:
Here is the link to your drivers and as far as them not having them anymore it might be a cost saving idea.Bad move for customers.There just not carrying a lot of the drivers on the servers for devices that they sold from years prior then 2011.They sold the scanner in 2004 and they should keep they drivers available for a reasonable 25 years it's only data.
good luck hope it helps.
http://members.driverguide.com/driver_search.php?q=Canon+CanoScan+3000ex&si=92bd74e81599e023ef8c5e4d602b0214&st=1311734158&gqm0=Canon+CanoScan+3000ex
Posted on Jul 27, 2011
CANNOT INSTAL CANON n1240U SCANNER ON WINDOWS 7
Your scanner model is not supported on windows 7.
Jun 07, 2011 | Canon CanoScan N1240U Flatbed Scanner
I have lost CD of Canonscan D1250U2.How can I get Its driver & software?
You can find it through Canon USA's website: http://www.usa.canon.com/cusa/support/consumer/scanners/canoscan_series/canoscan_d1250u2f#DriversAndSoftware
Feb 28, 2011 | Canon CanoScan D1250U2 Flatbed Scanner
I have OS window 7, i want to use the scanner CanonScan LiDE 30, can i used in this operating system.
Unfortunately , there are no drivers available under Windows 7 for this excellent unit and it's a shame .
You can verify here :
http://software.canon-europe.com/products/0000466.asp
Regards .
Jan 08, 2011 | Canon CanoScan LiDE 30 Flatbed Scanner
I can't found any drivers for the Scanner "CanonScan D1250U2F" on Windows 7 or on Mac X ???
drivers for canon canoscan D1250U2F......go to ... canon.ca
click on drivers for scanners and pick the model you want them for..
if you are in canada make sure that you click on drivers available in canada..
Good luck ...Jake
Jan 04, 2011 | Canon CanoScan D1250U2F Flatbed Scanner
Is there a driver for Canonscan D646U Windows 7 available?
hi you can try using the windows vista driver that normally works...hope this helps
May 10, 2010 | Canon CanoScan D646U Flatbed Scanner
I need a driver for canonscan n 650u for windows vista home premiun
There are no Vista/Win 7 drivers available for this model of scanner as it is too old and not supported by the manufacturer on these OS's at present.
May 06, 2010 | Canon CanoScan N650U Flatbed Scanner
Canonscan 4200F Flatbet does not work with Windows 7
I solved the problem by just buying an Epson Printer scanner for 75 dollars....
Jan 25, 2010 | Canon CanoScan 4200F Flatbed Scanner
Windows vista 64 bit driver
Hi mtrump1,
Thanks for your posting in FixYa.
The driver are available on the Canon Website, use this link to get it:
http://software.canon-europe.com/products/0000441.asp
or
For Vista 64 Bit you can try:
http://drivers.softpedia.com/get/SCANNER-Digital-CAMERA-WEBCAM/CANON/Canon-CanoScan-D1230U-611c.shtml
But i think both should be compatible to run in any 32 or 64 bit environment.
Regards
ELLIN
Sep 20, 2008 | Canon CanoScan D1230U Flatbed Scanner
CanonScan Lide 30 flatbed
You need the software called "Canoscan toolbox"...click on the link below and then select your operating system...you can also get the driver for the LIDE 30 on this page:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=351&modelid=6623
Jul 26, 2008 | Canon CanoScan LiDE 30 Flatbed Scanner
Canon CanoScan 3000ex Flatbed Scanner Logo
old marine
old marine
efs_perpends
efs_perpends
