Question about Wells F-67 21167 Deep Fryer
I need a manual to replace a thermostat where can i get one for a well f-67
Posted by jessepacheco on
Angel Joseph Jr.
  • Wells Expert
  • 684 Answers
Hi there.
You can visit http://www.wells-mfg.com and look for the nearest authorized parts and service dealer.
Regards.
Posted on Jul 28, 2011
What can i get wiring diagram for TPP-67 pizza table?
TRUE TPP-67 SPECIFICATIONS Pdf Download. - ManualsLib
www.manualslib.com > ... > True Manuals > Kitchen Appliance > TPP-67
True TPP-67 Food Prep Tables: Specifications. TPP-67 ... TPP-67. Solid Door Refrigerator. TPP-67. True's pizza prep tables are ... Heavy duty PVC coated wire.
Aug 06, 2014 | True TPP-67 Commercial Refrigerator
Braeburn 1200 thermostat cool air blows out when set to heat
I have a feeling your thermostat needs replacing. Check and see if there is a little screw that you can set to increase the temperature on the thermostat.
Oct 24, 2017 | Heating & Cooling
Directions to program cm 67 thermostat
How do I set one temperature for the whole day?
To operate as a simple thermostat with one temperature throughout the day, move the slider to the MANual position. Adjust the manual temperature by pressing the TEMPerature or button. The manual temperature can be set anywhere from 5°C to 30°C in 0.5°C steps.
Here is the User Guide for the CM67 Thermostat:
http://www51.honeywell.com/pacific/common/documents/CM67_User.pdf
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
May 17, 2011 | Honeywell Heat/Cool Thermostat
I need an operating manual for honeywell thermostat RLV450
Hello, here is a link to the manual in a pdf file http://customer.honeywell.com/techlit/pdf/67-0000s/67-5129.pdf
May 03, 2011 | Heating & Cooling
I have the thermostat set for 70 degrees on the white rodgers programmable thermostat. The heat runs until the room is 70 degrees, but then the heat stops and the room cools off and the heater doesn't kick...
Based on your explanation this is an erratic operation of the thermostat, first thing that you need to check is the wiring make sure that all the wires are proper looped on the under terminals then reset the thermostat if the problem still persist I think you need to replace the thermostat. If you need further support call the homeowner techline 18002842925.
Jan 03, 2010 | White Rodgers White-Rodgers 1F85RF-275...
DPDT thermostat for Singer baseboard heater.
as close as I've found
http://keithspecialty.com/k/67-411.htm
http://www.heater-store.com/specialty-thermostats_91_ctg.htm
Nov 02, 2009 | Honeywell Programmable Thermostat Heater
Replace three wire thermostat with four wire thermostat
From the two red and two black wires (and the specs in the pdf), your new thermostat sounds like it's designed to directly control the line voltage (120 or 240) to the heater. That's the usual way baseboard heaters are controlled.
Could your wires be red, black, and (old, yellowed) white, the standard colors in a 3-wire power cable? Just the red and black should be enough to control a 120-volt heater so I don't understand what the white would have been used for. If it were my heater I'd take off the cover(s) -- with the power off, of course -- and find out what those wires actually connect to.
Jan 26, 2009 | Honeywell Programmable Thermostat Heater
My central ac system occasionally runs too long and the temperature gets way too cold. The digital thermostat reads that the temperature is too high so the ac still runs. This doesn't happen all the time...
I have seen this is many digital thermostats. The worst problems usually come from the touchscreen thermostats. I would suggest installing a new thermostat. Make sure that you read the instructions before you even remove the old one.
Jul 03, 2008 | Heating & Cooling
Wells F-67 21167 Deep Fryer Logo
Top Wells Kitchen Appliances - Others Experts
Dennis Boxerman
ray gallant
Stan Ford
Are you a Wells Kitchen Appliances - Other Expert? Answer questions, earn points and help others
