Question about Samsung SGHa887 Cell Phone
How do l configure my at&t samsung with MTN network gprs (i.e set name,access name, Auth type,User ID,Password,protocol,Home URL,proxy address,linger time,ADVANCE SETTING:Static IP,Local IP,Static DNS,Server 1,Server 2,Traffic class.kindly send me all this settings thanks
Posted by abiodunrauf on
francis joan
    President:
  • 1,696 Answers
Well if you are tied to a particular network all you have to do is to unlock your phone to use it any other GSM network. You can get the unlock code through online. Give your IMEI number & get the unlock code for ur mobile .............You also get through online..........I will suggest the website Unlock-Zone.com which is doing good service .....you can approach this website.
Posted on Jul 27, 2011
How do i change my apn settings on my eternity so i can use the straight talk network
From the main screen of your phone open you menu, then messaging, then messaging settings, then multimedia message, then MMS profiles. from there create a new profile and fill in these settings:
Set Name: Straight Talk
Access Name: att.mvno
Auth Type: Normal
User ID: *leave blank*
Password: *leave blank*
Protocol: HTTP
Home URL: http://mmsc.cingular.com
Proxy Address: proxy.mvno.tracfone.com:80
Linger Time: 300
*leave advanced settings alone*
Save your profile and select it using the square on the right of the screen. You should now beable to recive multi-media text messages. Exit out to your phone main screen.
Press menu, then Media Net, then Browser Settings, then Browser Profiles, then select the profile named straight talk by pressing the square on the right side of the screen. You should then be all setup to use all forms of data and messaging on your new Straight Talk plan. I hope this was helpful!
May 02, 2012 | Samsung Eternity Cell Phone
Tip
Gprs & MMs settings for india mobile networks 2
&gt;IDEA GPRS SETTING <span> </span> <span> </span>#Account Name - Idea GPRS <br /> <span> </span>#Username - <br /> <span> </span>#Password - <br /> <span> </span>#Homepage - http://wap.ideafresh.com <br /> <span> </span>#Proxy and Server Port - 8080 <br /> <span> </span>#Proxy and Server adress - 10.4.42.45 <br /> <span> </span>#Databearer - GPRS / Packetdata <br /> <span> </span>#Acces Point Name - imis <br /> <span> </span>#Proxy - Enabled/yes <br /> <span> </span>#Authentication Type - Normal<span> </span> <br /> <span> </span>&gt;IDEA MMS SETTING <br /> <br /> <span> </span>#Connection name - IDEA_MMS <br /> <span> </span>#Databearer - GPRS <br /> <span> </span>#APN - mmsc <br /> <span> </span>#User name - <br /> <span> </span>#Prompt password - No <br /> <span> </span>#Password - <br /> <span> </span>#Authentication - http://10.4.42.21:8002 <br /> <span> </span>#Proxy serv. address - 10.4.42.15:8080 <br /> <span> </span>#Proxy and server Port - 8080 <br /> <span> </span>&gt;VODAFONE GPRS SETTING <br /> <span> </span>#Account Name: Vodafone_gprs <br /> <span> </span>#Homepage: http://live.vodafone.in <br /> <span> </span>#User Name: <br /> <span> </span>#Pass: <br /> <span> </span>#Access Point Settings: <br /> <span> </span>#Proxy: Enabled <br /> <span> </span>#Proxy Address: 10.10.1.100 <br /> <span> </span>#Proxy Port: 9401 <br /> <span> </span>#Data Bearer: Packet Data <br /> <span> </span>#Bearer Settings: <br /> <span> </span>#Packet Data Access Point: portalnmms <br /> <span> </span>#Network type: IPV4 <br /> <span> </span>#Authentication: normal <br /> <span> </span>#User Name: <br /> <span> </span>#Password: <br /> <span> </span>&gt;VODAFONE MMS SETTING <br /> <span> </span>#AccountName:- vodafone <br /> <span> </span>#Server:- http://live.vodafone.com <br /> <span> </span>#Proxy:- 196.006.128.012 <br /> <span> </span>#Proxy Port:- 8080 <br /> &gt;BSNL GPRS SETTING <br /> <span> </span>BSNL PORTAL <br /> <span> </span>#Account Name - Bsnl Portal <br /> <span> </span>#Username - <br /> <span> </span>#Password - <br /> <span> </span>#Proxy - Enabled/yes <br /> <span> </span>#Acces Point Name - celloneportal <br /> <span> </span>#Homepage - wap.cellone.in <br /> <span> </span>#Proxy and Server Adress - 192.168.081.163 <br /> <span> </span>#Proxy and Server Port - 8080 <br /> <span> </span>#Data Bearer - GPRS / Packetdata <br /> <span> </span>#Authentication Type - Normal <br /> <span> </span>BSNL NORTH <br /> <br /> <span> </span>#Account Name - BSNL GPRS <br /> <span> </span>#User Name - <br /> <span> </span>#Password - <br /> <span> </span>#Proxy - Enabled/yes <br /> <span> </span>#Homepage - http://petercrys.com <br /> <span> </span>#Proxy and Server address - 192.168.051.163 <br /> <span> </span>#Proxy and Server Port - 8080 <br /> <span> </span>#Acces Point Name (postpaid) - www.n.po <br /> <span> </span>#Acces Point Name (prepaid) - www.n.pr <br /> <span> </span>#Data bearer - GPRS/ Packetdata <br /> <span> </span>#Authentication Type - Normal <br /> <br /> <span> </span>BSNL SOUTH <br /> <span> </span>#Account Name - BSNL GPRS <br /> <span> </span>#User Name - Your mobile no <br /> <span> </span>#Password - <br /> <span> </span>#Proxy - Enabled/yes <br /> <span> </span>#Homepage - http://localhost/home.wml <br /> <span> </span>#Proxy and Server address - **** <br /> <span> </span>#Proxy and Server Port - 8080 <br /> <span> </span>#Acces Point Name - bsnlsouth <br /> <span> </span>#Data bearer - GPRS/ Packetdata <br /> <span> </span>#Authentication Type - Normal <br /> <br />
on Jan 11, 2011 | Cell Phones
Internet setting
To set up internet setting in your Samsung S5620, if your an O2 customer follow this steps:
  1. Tap Menu
  2. Tap Settings
  3. Tap Application settings
  4. Tap Internet
  5. Tap Internet profiles
  6. Tap Create
  7. Tap the Set name box and enter O2 Pay Monthly then tap Done
  8. Skip past Bearer type as this is preset as Packet data
  9. Tap the Access name box and enter wap.o2.co.uk then tap Done
  10. Skip past Auth type as this is preset as Normal
  11. Tap the User ID box and enter o2wap then tap Done
  12. Tap the Password box and enter password then tap Done
  13. Skip past Protocol as this is preset as HTTP
  14. Tap the Home URL box and enter http://wap.o2.co.uk then tap Done
  15. Tap the Proxy address box and enter 193.113.200.195:8080 then tap Done
  16. Tap the Linger time (sec) box and enter 300 then tap Done
  17. Tap Save
  18. Tap O2 Pay Monthly to make it active (a blue tick should appear next to the active profile).
  19. Switch your handset off and then back on to complete your settings.
    The settings are now complete.
Mar 31, 2011 | Samsung S5620 Cell Phone
How to open smart gprs for my samsung star?
hi, if you are from philippines, you would want to do this... press message, then type this to your keypad. for SMART Internet settings,  type SET INTERNET  S5233 and send to 211, wait for configuration and install it to your phone.  go to your menu, press internet, select settings, select browser profiles, press the double arrow or >> to edit the acount, scroll down and select advance, check your static DNS to enable it and type the following server address to your server 1 ; 202.057.096.003 press save and exit the settings.
to configure your samsung star for wap or gprs,  you can do the same thing, type in your message SET GPRS S5233 and send to 211, wait for configuration, save it and make it as default browser profile.
if you want you can also do this manually.  1.   press menu 2.   select internet 3.   select settings 4.   select browser profile 5.   press create on the following boxes type this SET NAME ; SMART WAP BEARER TYPE : UMTS/ connection less (depending on your network) ACCESS NAME: WAP.SMART.COM.PH AUTH TYPE : NORMAL user id : smartwap password : smartwap protocol : WAP home url : www.smart.com.ph/wap proxy address : leave it blank linger time: leave it as it is press advance settings : check static ip address input this 10.102.61.46 leave static DNS. or if it ask,  check it and input 202.057.096.003
Mar 03, 2010 | Samsung Star GT-S5233 Cell Phone
Att mms setting for lg ku990
This is the configuration of your LG KU990 (Viewty).
Title:
Att
Bearer: GPRS
Auth: PAP
User: [email protected] (all caps)
Password: CINGULAR1 (ALL UPPERCASE)
APN: wap.cingular
Browser>Settings>Profiles: (Internet Setting)
Service Name: Media Net
Homepage: http://www.google.com
Connection mode: TCP without proxy
IP: (blank)
proxy: (blank)
Security: (blank)
Access Point: ATT
Messaging>Settings>MMS>MMS center: (MMS setting)
Title: ATT MMS
MMSC URL: http://mmsc.cingular.com/
Connection Mode: TCP with Proxy
Access point: ATT
To get google and all your other java web access make sure that this is the only profile you have in the Access Point. This will default as your java web setting & streaming setting. So you can now stream youtube & use Opera Mini 4.
Best regard:
Henk®Muskita ©2009.
Aug 07, 2009 | LG KU990 Viewty
Can not send or receive multimedia messages.
Maybe internet is shut off on your phone?
Here are the internet settings for Cingular: Internet Setting Cingular:
Profile Name: Cingular
GPRS setting:
APN: wap.cingular
User Name: WAP @ CINGULARGPRS.COM
Time Out: Off
Primary Gateway IP: 66.209.11.61
Port: 9201
Secondary Gateway IP: 0.0.0.0
Port: 0
DNS Server:BLANK
CSD setting:BLANK
Dial in number NONE
Query at Logon: (NO CHECK MARK)
User Name
Password
Baud Rate Auto
Line Type: ISDN
Time Out Off
DNS Server:
Then go to your browser and enter the following settings:
Profile Name: MEdia Net
Homepage: device.home
Network Link: Cingular
MMS Settings:
Profile Name: MMS over HTTP
MMSC: http : //mmsc.cingular.com/ (No Spaces)
Max Sending Size: 30K
Network Profile: Cingular
and T Mobile: Internet Setting T-Mobile
T-MobileWeb Settings:
Primary IP Address: 216.155.165.050
Secondary IP Address: (Blank)
Access Point Name (APN): wap.voicestream.com
Data Bearer: GPRS
Profile Name: GPRS
Username: (Blank)
Password: (Blank)
Home Page: http://wap.myvoicestream.com
Picture Messaging Settings:
Multi-Media Service Center (MMSC) Address: http://216.155.174.84/servlets/MMS
Validity Period: 72 hours
Hide ID option (if option exists): set to off, no, or disabled
and Fido: Internet Setting FIDO
Profile name: FidoWAP
GPRS setting:
APN: wap.fido.ca
Username: fido
Password: fido
Timeout: 15 minutes
Primary Gateway IP: 205.151.11.11
Port 8080
Secondary Gateway IP: (blank)
Port: (blank)
DNS Server: (unchecked)
CSD Setting:
Dial in number: (blank)
Query at logon: (unchecked)
Username: (blank)
Password: (blank)
Baud Rate: Auto
Line type: Modem
Timeout: Off
DNS server: (unchecked)
Then press Save.
To get MMS working (what I haven't included are the blanks and all boxes should be unchecked unless specified)
Setup-->Data Network
Profile Name: Fido MMS
APN: mms.fido.ca
Username: fido
Password: fido
Timeout: 15 minutes
Primary Gateway IP: 205.151.11.13
Port: 8080
Baud Rate: Auto
Line type: Modem
Timeout: off
Then click SAVE.
THEN
Messages-->Service Setup-->Multimedia Message
Default profile: FidoMMS
(all other settings are to your preference)
Tap the box beside Default Profile and ensure that FidoMMS is the default profile.
Settings for MMS profile goes
Profile name: FidoMMS
MMSC: http://mms.fido.ca
Max Sending Size: (your preference)
Network Profile: Fido MMS
and Rogers: Internet Setting Rogers
Proxy Name: Rogers MMS
Proxy Address: 172.25.0.107
Access Point: Rogers MMS
Home: ((Set whatever page you like here))
Port Number: 8080
Authentication Type: HTTP-BASIC
User Name: media
Password: mda01
Access Point Name: Rogers MMS
APN: media.com
Authentication Type: PAP
User Name: media
Password: mda01
DNS: <>
Linger Time: 180
MMS Accounts (Main Menu -> Messaging -> Messaging Settings -> MMS Settings)
Profile Name: Rogers MMS
Proxy: Rogers MMS
Relay Server URL: http://mms.gprs.rogers.com
Feb 19, 2009 | LG Shine KE970 Cellular Phone
Need help with my lg shine ke970
Set the homepage to: http://device.home
Set the Bearer: GPRS
GPRS settings:
APN: wap.cingular
User ID: [email protected]
Password: CINGULAR1
1. Scroll to and select Proxy Settings and press OK.
* IP Address: 66.209.11.32
* Port Number: 80
2. Press the End call key to return to the standby screen
I found this on the web, its a little different then how I did mine, so here it is in case mine doesn't work for you:
here you go...it works !!!
Phone Setting>Connectivity>Access Point: (Data Setting)
Title: Att
Bearer: GPRS
Auth: PAP
APN: wap.cingular
IP: (blank)
proxy: (blank)
Security: (blank)
Access Point: ATT
Title: ATT MMS
Access point: ATT
Oct 16, 2008 | LG Shine KE970 Cellular Phone
GPRS setup for Samsung Blackjack i607
Start--Settings---Connections---GPRS
Click at menu---New--- Connection name
Connects to The internet
access point name as provided by Tele provider
user name and password as by provider
ip address: as by provider
done
go to proxy
Connects from The internet
Connects to WAP network
proxy:port
type : http
Username and password as by provider
Kayshan98
Feb 03, 2008 | Samsung Blackjack SGH-I607 Smartphone
Gprs settings
For BSNL South prepaid or post paid use following settings:
Start/ Settings/ Connections /GPRS
Connects to : Internet
Access point: gprssouth.cellone.in
Leave other items blank.
Start/ Settings/ Connections /Proxy
Donot creat any proxy
You donot require any thing else. GPRS will work on your mobile and also in Internet share. Internet share works with cable and bluetooth. Browse on mobile or laptop !!!
9448834529
Dec 10, 2007 | HTC Touch P3450 Smartphone
Samsung SGHa887 Cell Phone Logo
510 people viewed this question
Top Samsung Cell Phones Experts
Muntejaya Ginting
Muntejaya Ginting
Michael Thomas
Michael Thomas
Marvin
Marvin
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
