Question about HTC G1
Ok so i got a G1, and the problem is it wont turn on. even when i charge it, it wont turn on. The farthest it goes it to opening where it says G1 and then it turns off after that. Whats wrong with it, do i need a new battery?
Posted by faris_24 on
Thyake
  • 341 Answers
Try hard resetting it once. But make sure you have enough charge. But this will erase everything.
To perform a Hard Reset
  1. Turn the phone off. If it is frozen, take the battery out and put it back in.
  2. Hold the Home and Power keys down at same time for about 25 seconds. You will see a yellow triangle screen with exclamation point in the middle.
  3. Press Alt+L.
  4. Press Alt+W for a factory reset.
  5. Press the Home and Back keys again for about 25 seconds.
http://www.resetcellphone.com/solution/HTC/g1
Posted on Jul 27, 2011
  • julian benitez Mar 19, 2013
    when i try it it only shows a blue light plz help me
I bought my g1 about 1 month ago and now its just slow, draining battery fast, and getting really hot. anyways one night i left my G1 on my desk next to a cold ice bottle of water and the next morning my...
the mobile requires a service with solution dipped in liquid, as few resisitors and capcitors might have been still corrosive, i think you please leave the phone without battery in room temp of 26-30 deg ... for a day or two...
Jun 16, 2011 | HTC G1
Wont charge. i plugged into so many usb cables and box chargers and light wont turn on nothing charges it
Your charging port is probably bad. It is a common issue. You can take it into an electronics shop and they could fix it by sending it to the manufacturer, but it might cost more than a new phone like the HTC incredible
Mar 01, 2011 | HTC G1
My g1 wont turn on when i try to hit the power button the top light turns blue and when i do the reset it dose the same thing
Is the battery charged? Is the charging LED showing up as normal when you connect the charger? Try charging the battery for a few hours and then try to reset the device?
May 04, 2010 | HTC G1
Phone dies 10-15 minutes after being fully charged. it diesnt shut down it just dies, it goes black even though you still see the etching of what was on the screen. i turn it back on and it gets to the...
Sounds like you have a defective battery. One can be purchased fairly cheap on ebay, or you might find one at your local phone store, but they will be much more expensive.
Dec 05, 2009 | HTC G1
My g1 wont turn on but if i charged it and try to turn it on it would vibrate but the screen is still pitch black
so..i had jst got a warrantee on my g1...and recieved it today..but it will not turn on..could u help?
Oct 12, 2009 | HTC G1
My g1 will not charge fast like it use 2
Have you tried recalibrating the battery? To do this you use the phone until it completely runs out of battery and switches itself off. Make sure it has completely run out by continuing to turn it back on until nothing happens except a red LED coming on. Then charge it while it's off until the green LED has been on for 2 hours. Hopefully this will improve your battery life.
Jun 10, 2009 | HTC G1
Blue On G1
ok i had this isssue and figure out what to do. this is all afterm you know that you have a good charger and or battery.
1. completely turn of phone unplug charger.
2. take and put battery back in phone and plug charger.
3. hold hit camera button and power buton. phone will come on if the update was washed it will come straight on. if not you will see the blue LED dont worry yet. just keep holding for 15 sec.
4. while phone blue LED is still on hit and hold (drum Role) menu and track ball for 15 sec.
5. now unplug charger and take out battery. wait 10 sec
6. now put battery back in and leave charger off. and turn on. unless you was in middle of update and hardware failed this WILL bring your G1 back up and running.
hope this helps everyone . MIll$tronics signing out.
Mar 05, 2009 | HTC G1
Screen wont turn on
You are going to have to ty a hard reset. Don't worry about things being deleted from the phone, as your phone auto syncs with Gmail when you enter your account info again.
To hard reset...turn the phone on while holding home and back. Follow on screen prompt.
If that doesn't work try..
Hold home and power buttons
once phone is on, open keyboard and hold alt first + w
Feb 27, 2009 | HTC G1
My g1 wont install on vista?
ok people i have solved the problem with the g1 not recognizing being hooked up to the computer. the usb cords that are sent with the g1 are very crappy. use another usb mini to connect to your computer. theres no installation required just hook it up and select mount and open up my computer and go to removable disk to access you files.
Dec 30, 2008 | HTC G1
G1 Phone Wont Charge
take the batteries out and put it back in again and try charging check in diff power sockets press the end of the charging cables with little amount of pressure and have a check try to connect via the usb cable to the computer and check if it charges, if works the charger is faulty if still did not work then it will be firmware problem with of phone
Nov 03, 2008 | HTC G1
HTC G1 Logo
406 people viewed this question
Top HTC Computers & Internet Experts
Tom Chichester
Rob Woolcock
Rob Woolcock
Marvin
Marvin
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
