SOURCE: DVD player won't play audio cd
clean the laser lens as they could be dirty,if that does not work take it to a tech for a check and repair.lens might need to be replaced.
SOURCE: whats region 1 dvd?
dvds are coded differently depending on which region of the world they are intended for. there are eight regions - check this link for more info; http://www.amazon.co.uk/gp/help/customer/display.html?nodeId=502554 this was a pointless idea that was supposed to limit video piracy, but only actually causes problems and increased production costs The US is in region 1, so the problem is the settings on your dvd/vcr as to what region it is coding the discs as. You may be able to change this in one of the menus, but it may be designed for only one region code output. Check the manual - if you need a manual or have trouble then please post the make and model of your dvd vcr recorder and we can try to help Hope this helps you :)
SOURCE: DVD player recorder won't read or play any disc
This just worked for me. Don't know how long it will last though. I found it on this webpage
http://forum.ecoustics.com/bbs/messages/15118/130292.html
To do a reset:
On the remote control press the SETUP button,
Press the right key on the remote 3 times,
The Preference page will show up,
Press the down arrow five time to highlight
"default", hit right arrow to highlight "reset"
Press enter to reset. Turn off/on machine, etc.
SOURCE: DVD Player freezes on some commercially produced DVDs
The microprocessor or memory componets on the player isnt functioning asits supposed too. This is rather troubling and there isnt any easy fixes possible.. My suggestion is seeing as its new return it and get a replacement. Chances are it will fail very soon.
SOURCE: Insignia Portable DVD Player does not play DVDs - says no Disc?
