Epson Aculaser C1100 Printer Logo
Posted on Jul 26, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Aculaser C1100 After replacing the black toner cartridge with an original new, high capacity one the prints come out with many, uneven vertical gray bands. Cleaning the print head did not help. Reinstalling the black cartridge made it worse.
Stan
Level 3:
  • Master 748 Answers
  • Posted on Jul 26, 2011
Stan
Master
Level 3:
Answers
748
Questions
0
Helped
268404
Points
2393
A print cartridge (or a drum unit if it's separate from toner container) has a thing called wiper blade; it's essentially a rubber (sillicone) strip that wipes any "leftover" toner off the drum. When this strip is positioned wrong or faulty it gives symptoms similar to what you describe.
Sometimes it develops such behavior after long usage (especially if the cartridge was repeatedly refilled with toner), but in rare cases it may come like this new, due to manufacturing defect. I had this a couple of times in my career.
If you take out the cartridge and in subdued light (not to expose the drum to too much light) try to push the gear wheel so that the drum revolves (don't ever touch the shiny drum surface with fingers!) you can look at the drum; if you see toner streaks instead of a clean drum then you need to claim this cartridge as defective with the supplier. You should get a replacement without problems.
Please come back and leave a rating/testimonial if helped or post a comment for further assistance.
Thank you for using FixYa, the community-based help site :)
Canon irc4580i print dark problem
In the process used printer, will be inevitable printed page by your printer have the bad quality prints. For example: Toner specks, Light image, Vertical line, Dropouts, background, Toner smear, Vertical black line and band, Vertical white line, Background scatter, Black pages, Loose toner, Horizontal stripes, Ghost, Uneven Density, poor fusing ...
The common print quality problem Canon IRC-4580 printer
Currently, The Canon IRC-4580 is the laser printer have high speed, easy to use, friendly for user and printing clear text.
However, we can not avoid the damage of some components of the printer when used.
In this article, I will introduce some basic errors with printing quality problems of Canon IRC-4580 printer and "How to fix it".
After viewed artical, you know:
- How to fix (repair/solve) Vertical line (black or white) in Canon IRC-4580 printer
- How to fix (repair/solve) Poor fusing (loose toner) in Canon IRC-4580 printer
- How to fix (repair/solve) Uneven Density in Canon IRC-4580 printer
- How to fix (repair/solve) Light image in Canon IRC-4580 printer
- How to fix (repair/solve) Ghost in Canon IRC-4580 printer
1. Fix print quality problem "Vertical line" for Canon IRC-4580 printer How to fix print quality problem Vertical line
This plobrem "Vertical line" is usally error of Canon IRC-4580 printer. For this "Vertical line" error, technicians divided into two smaller error are: Vertical black line and band and Vertical white line.
Description:
- Vertical line and band: On the printed image appear some straight thin black vertical.
- Vertical white line: On the printed image appear some white vertical voids.
Error location:
- Surface of the charge roller
- OPC drum
- Cleaning blade
- LSU unit
- Developing roller
Cause of error "Vertical line" on the printed page:
- May be surface of charge roller scratched or dirty by toner powder.
- May be have some grooves on the OPC drum.
- May be cleaning blade is damaged.
- May be LSU window or LSU lense has dirty.
- May be surface of developing roller has scratched.
How to fix(repair) "Vertical black Line and Band" for {{SPkey1}} machine:
- Replace the charge roller of toner cartridge.
- Replace the OCP drum.
- Replace the cleaning blade
If printed page are not improved
- Clean the LSU unit by soft cotton cloth and try to print. If Vertical line is not clear on the printed page you should replace LSU unit.
- Replace new axis developer and try to print
2. Solve print quality problem "Poor fusing (loose toner)" for Canon IRC-4580 printer. How to fix print quality problem loose toner
Description loose toner: Toner is not properly fixed on paper, use to hand rubbing lightly on the printed image toner powder may be stick in hand
Error location: toner cartridge or fuser unit
Cause of error "Dark Image or black" on the printed page:
When toner cartridge is empty. You toner refilled by toner powder ware not compatible. This is makes toner cartridge components demaged and temperature of fuser unit is not enough melt to toner powder
How to fix(repair)"Poor fusing (loose toner)" on the printed page for Canon IRC-4580 printer:
With this error, you should replace toner cartridge or fuser unit to fix it.
3. How to fix print quality problem "Uneven Density" for Canon IRC-4580 printe How to fix print quality problem Uneven Density
Description: The printed page has one half light and one half clear.
Error location: Toner cartridge, transfer roller, springs, doctor blade
Cause of error "Uneven Density":
- The pressure force on the left and right springs of the transfer roller is not even.
- May be toner low also causes this error
- Doctor blade has bent
How to repair error "Uneven Density" on the printed page for Canon IRC-4580 printer:
- Replace springs and transfer roller.
- Toner refill toner cartridge Canon IRC-4580 and reset toner cartridge chip (replace new chip) or replace new genuine toner cartridge.
- Replace doctor blade.
4. How to solve print quality problem "Light image" for Canon IRC-4580 printer How to fix print quality problem light image
Description: The printed image is all light and no Ghost.
Error location: Toner cartridge, Developer, HVPS board
Cause of error "Light image" on the printed page
- Enabled toner save.
- Toner cartridge is low
- OPC drum may be faulty by strong light intensity
- Temperature in room is below than 10*C
- Bad contact caused by the toner dirty between the high voltage terminal in the HVPS and the one in the set
- Abnormalities output from the HVPS
How to fix(repair) error "Light image" on the printed page for Canon IRC-4580 printer:
- Disable toner save by change in printer driver.
- Replace the OPC drum.
- Replace developer.
- After printer is power on, wait 30 minutes then start printing
- Clean up the contact between the high voltage terminal in the HVPS and the one in the se- Replace the new HVPS if the problems are not solved by 4 away above.
5. How to fix print quality problem "Ghost" for Canon IRC-4580 printer How to fix print quality problem Ghost
Description: Ghost occurs intervals of the OPC drum or transfer roller.
- OPC drum has fauty.
- The life of the transfer roller has been expired
- The high voltage terminal is contaminated by toner powder or
- Replace OPC drum
- Replace transfer roller
- If performed 2 away and the error does not clear, you should replace ganuine toner cartridge .
- Replacce HVPS board.
Where can i find a epson Aculaser Y dev unit from please
The Y toner cartridges are still being produced by Epson. However not many stores in UK stock them. They are readily available on eBay. You will have a choice of originals or compatibles, and a choice of standard or high capacity cartridges.
I normally stick to originals, and pay around 20 UK pounds for standard and 40 UK pounds for high capacity ones.
Compatibles are about half of those prices, but I have found wide variation in quality.
If you are not using a lot, then originals are preferable.
Let me know if I can be of further help
Trevor
2answers
The black toner needs replacing but I can't get to it. The Cyan toner is at the front and I can't move it round to get to the black! It's an Epson Aculaser C1100
there maybe a cartridge replacement button to drag the print head etc out of the way so you can get at the cartridges.
I hope this was helpful
2answers
Where abouts is toner k
K toner is refering to black toner. Here is a link to Epson for your Aculaser C1100 Reference Guide. Look under Setup & Maintenence for >Replacing Consumable Products..... click on 'Toner Cartridge' for the proceedure.
http://support2.epson.net/manuals/english/page/aculaserc1100/ref_g/index.htm
1helpful
11helpful
2answers
What colour is K on low ink
Toner K low refers to the black toner.
1helpful
Toner Capacity
This does not need to be done. there is a chip/fuse built into the toner that basically tells the printer how many paes that toner has printed in its life time. no adjustment is needed it is all automatic
Epson Aculaser C1100N - Black Toner problem
IF the problem persists with an original cartridge then the factory settings should be restored refer the manual or go through the settings in the control panel . minimise the tone of printing . If toner is getting accumulated in the printer then it might be due to refilled toner not the original cartridge . use the original cartridges
2answers
Black Toner replaced
Replace Toner with gen cartridge.
Or Take cartridge back as faulty after checking that it was opened and installed correctly.
Check display on printer for indications that maybe it needs one of the 3 colour toners indicators are Y,C or M
K is black
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
