SOURCE: Teac GF-350 CD Shelf System
Firstly double check that the recordable discs you have bear the label "Digital Audio" on them as per the attached picture. Secondly what happens when you go through the finialise procedure in the manual? Do you see the ?FIn--d? display when you select the finialise button? Do you see ?NO TOC? and ?REC? indicators blinking at the next step? Please update the question & let us know if the information given was useful to you - Good Luck!
SOURCE: My Teac dvd/cd-rewritable w28e CD-RW, won't read any discs!
if you just installed this device you will have to go to the utility manager and make sure all the functions are turned on, do you have windows xp. what os are you using and i can give you instructions how to go this.
SOURCE: DVD player trouble after new laser pick-up
ok, this is a compatibility issue.try looking at the lens but not directly if it lights on when loading a disk.if ok.make sure the ribbon wire is securely attached especially the the terminal are not folded.
SOURCE: When playing a DVD, picture & audio stop for a second one a while, no problem when playing a CD
this may just be the mechanism changing diretion as it reads the second layer on the disc usually because the film is too long to go on one side of the dvd disc.
quite normal.
but if happening quite a lot during playing a film then it could be something as simple as cleaning the mechanism. NOT for the untrained
SOURCE: My teac dvd/cd player wont play some cds
Probably a codec problem on the notebook. rather than a drive problem. Try a 3rd party media player such as Real Player or Quicktime
