Question about Proscan 32LB30QD 32 in. LCD TV
I put a dvd in and it says it is loading and then it says no disc found even though it is in the dvd player. I have tried several different dvd's.
Kazim ERGUNEY
  • 577 Answers
Unfortunately , Some DVD players cant read some DVD s and
then it gives either "loading" or " no disc"..reading on the display...
it generally happens when you want to play "A copied DVD/CD " taken from somewhere else..
Just to make sure that such DVD is ok ,you can try to run them on your laptop.If the disc itself has problem, laptop does not read either..
Since you h
ave not stated,if it is an old player pls Clean your DVD player's LASER lens anyway .. A clean DVD player Lens ensures that your DVD disc would be read properly. Unfortunately, your DVD player's Lens accumulate as much dust and lint as the other parts of the DVD player. There are many available DVD lens cleaner kits that you can purchase and use to clean your DVD player.
YOUR DVD disc itself should be clean and finger prints free as well....
Here are three suggested DVD Lens Cleaner that should do the job of cleaning your DVD Player's lens.
Memorex Laser Lens Cleaner for DVD - This cleaner contains six soft brushes that gently remove dust, dirt and other airborne contaminants from your DVD player's lens. (Price: $6.09)
Maxell DVD-LC DVD Lens Cleaner - This DVD Lens cleaner features the "Thunderon Brush System" and include tests for audio performance including Dolby 5.1 surround sound. It also features an interactive on-screen instructions in 8 languages including system set-up. (Price: $10.81)
Allsop 23321 Carbon-Edge DVD and CD-Drive Cleaner - This DVD Lens Cleaner features an 8 brush carbon-system with carbon edge that removes static build-up from your DVD Players. It prevents skipping and also improves the sound and picture output of your DVD Player. ($13.11)
Hope this helps! Take care and please Remember to rate/vote and
give me 4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
Posted on Jul 26, 2011
  • 1 more comment
  • Anonymous Jul 26, 2011
    Already have tried the cleaner part too and I indicated tried other dvd's still doing the same thing and they are not copied dvd's so I guess my next questions is do I have to take it to a technician? Thanks
  • Kazim ERGUNEY
    Kazim ERGUNEY Jul 26, 2011
    Ok..great..if this is case your laser lens might need to be replaced or to be aligned by service..
    But be careful ,if it is not under warranty it may cost you more than a new DVD player...
    Ask for repair estimation first...
    Take care..
  • Kazim ERGUNEY
    One question..does your player play a regular Music CD ? pls try it..
When i put in a dvd, it makes clicking noises, after that a notice
follow this steps and fix it. God bless you
Does not play disc
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.
1helpful
2answers
Disc won't load
Try a different disc, one that worked before if problem still persists try and buy a lens cleaning disc that should solve your problem. If not, your optical laser head needs replacing.
When we put a disc in to play it, the player just continues loading and never actually plays the disc. what could be the problem? It is plugged into a wall outlet when we are trying & we have tried...
Check DVD discs for cracks,big scratches,dirts and grims?All DVD dics are original discs like comercial movies or materials discs?Most DVD players have problems,reading and playing copy discs,because of it finaling codes of the DVD copy recoders players used it to coping it.
2helpful
2answers
2answers
It cant read a dvd "no disc"
Check and make sure the laser eye is clean and clear of dust and smudges. With player OFF, blow across laser eye. Try cleaning with soft dry Qtip. Otherwise you probably have a bad laser drive or bad drive ribbon cable.
My recorder has stopped accepting NEW DVD-RW discs and ejects them. There is no problem loading DVD-R (new or recorded)or loading previous recorded DVD-RW, initializing and re-recording I have tried...
I had the same problem. After trying several brands, the only one which is working perfectly is Maxell (yellow discs). I found them is the US (Seattle), have not seen them in France where I am leaving. Hope it can help !
Problem loading disc
just open the loader and replace the lense.
DVD load problem
run a lens cleaner thru it to clean the lens. use the NON liquid type ... its a disc with little brushes on it you can get from radio shack for a few bucks.
2answers
Cyberhome 320 wont load discs
This dvd's fails because a dry capacitors on the alimentation source you need to send to a repair service center.
Proscan 32LB30QD 32 in. LCD TV Logo
Top Proscan Televison & Video Experts
Steven Wander
Steven Wander
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
