Question about Microtech JTX V5 15" Flat Panel LCD Monitor
Screen on JTX V 5 monitor has gone so dark I can not see anything. Besides it flickers on and off in the dark .
Posted by connexxions on
RockTheHood
  • 176 Answers
When it have this kind of error is a problem of the powerboard.
Anyway you must open it and look at the all capacitors and if are them inflated, if them are inflated must change them.
But can be a problem with inverters... control the transistors - MOSFET on the powerboard.
Posted on Oct 04, 2014
graeme ian hunter
    Genius:
  • 1,288 Answers
The back light is failing, and possibly the power capacitors for the HT circuit are failing to store the voltage necessary to power the screen, which would explain the flickering. This needs tested by an expert in monitors and TV's to confirm the actual source of the issue
Posted on Jul 26, 2011
Flickering monitor
sounds to me the screen is out try another one see if it comes on then
Feb 04, 2014 | Gateway FPD1530 15" Flat Panel LCD Monitor
My dell monitor is too dark
There is a small light behind TFT screen which must have gone bad
Feb 15, 2013 | Dell S2209W Monitor
My Dell 17 inch monitor keeps dying out. At first, it would flicker black and then go back to the original setting. Now, it flickers black and dies out -- the "on" button goes from green to...
You can verify that it is the inverter going out by turning the monitor on in a dark room and shining a light directly into the screen. If you cannot see anything, then something has happened to the power circuit. Perhaps the solder on the power port has gone bad, and needs to be redone, or part of the circuit board fried. The only way to figure this out is to open it up and take a look-see. If you don't wish to try this, you can always take it to a shop and have them look at it. Be careful opening it, the inverter is high voltage. Don't have any power going to the monitor if you do this.
Mar 11, 2011 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
The screen flickers, is dark, and makes sound
clear the dust inside the monitor...
Mar 13, 2010 | Computers & Internet
Monitor suddenly went dark. Switched it to another system but still dark. Power light on. V9s S1901D S/N T34F501728
Disconnected Data cable from the monitor to the back of the CPU. Do a self test on monitor if u get colors on the monitor it is working fine.
check for loose cables. Try to do factory reset on monitor using buttons on monitor.
Aug 17, 2009 | Scanport JTX V9S (Black) 19 in. Flat Panel...
Power the monitor and blank in fewsecnd
This could indicate your video card has gone bad.
May 23, 2009 | Microtech JTX V5 15" Flat Panel LCD...
My screen begins to flicker and turns too dark to see anything, the screen is still on but cant see anything. My monitor is only 4 months old.
bad capacitors are a plague they can be repaired and you may have a warranty to fall back on parts for 1 year normally check with the place you bought it and the company that made it.
otherwise you can repair them but it requires soldering skills let me know how it turns out.
Mar 22, 2009 | LG Flatron L1750S 17" LCD Monitor
MD96015 Monitor problem
Sounds like you may have a bad LCD backlight or inverter. When the screen is dark, take it into a dark area and see if you can see the screen dimly showing. Or, shine a flash light on the screen and see if you can make out anything showing up.
Try this and let me know what you find.
Ron
Dec 10, 2008 | Computers & Internet
Flickering then off
Problem is with Invertor Board maybe defective 2SC5707 transistors.
Samir
Jul 28, 2008 | BenQ FP71E 17" LCD Monitor
Microtech JTX V5 15" Flat Panel LCD Monitor Logo
Top Microtech Computers & Internet Experts
k24674
Are you a Microtech Computer and Internet Expert? Answer questions, earn points and help others
