Question about Stoves 720EF Electric Double Oven
Model 720EF. Model No 059040415. The grill will not work. The top oven is still working but the grill light or fan will not come on at all. Stoves have told me over the phone that it could be the microswitch, but that this part is now obsolete. Is there anything I can do, please.?
Posted by stuartbro440 on
Malcolm Parsons
  • 250 Answers
First things first. The top oven lights ONLY come on when the top oven is switched on. Operating the grill DOES NOT turn the lights on. If you wish to see what you are grilling, you have to turn the top oven control knob on to its first position as well as turning the grill on.
Secondly, the grill only works when the door is open. The grill does not work when you shut the door. When you open and shut the door, you should be able to hear the microswitch operating. It is located in the right hand side of the cooker, between the inner and outer panels - you cannot see it. I haven't seen the switch first hand but they normally come with an arm that contacts the door mechanism and the door mechanism operating, causes the arm to move, which causes a button on the switch to move and make the circuit. It has been known for the arm on the microswitch to bend with use so it no longer works correctly.
If you have checked all above and you hear the switch operating, then it could have failed. They are quite common, so if you can't get one from STOVES, try espares or someone like Maplin or RadioSpares.
The get to the microswitch you have to take the oven out of the housing and then take the right hand panel off. You should then be able to see it and check its operation.
All the best
Posted on Aug 20, 2011
Both lights on the top oven work when using it as an oven but when using it as a grill, they don't! There doesn't appear to be any other fault as the oven and grill still work fine. Any thoughts...
The unit is working as it should. The top oven lights will only come on when the top oven control knob is turned on. The grill control does NOT turn the lights on. If you want to see what you are grilling, then you should turn the top oven control on to its first position. This works even if the grill is operating.
May 10, 2011 | Stoves 720EF Electric Double Oven
Our top oven inner door glass for the model 720EF shattered and we need a new one. The number is 059040415.D you sell such a thing and if so how much?
Try espares. If the part is not listed, there is a section where you can leave your requirements and they will get back to you.
Apr 05, 2011 | Stoves 720EF Electric Double Oven
Hi Guys I have a Stoves 720EF Double Oven and Grill. Whilst halfway through cooking some sausages on the grill this evening, the grill suddenly stopped working (plus the LED for the grill knob showing...
If the element and the indicator light both stopped working this suggests a problem with the power supply for the grill control. Either the grill control has no power going to it or it is faulty and requires replacement. If you are not sure what you are doing you'd better get a tech. to look at it, it can be fairly complicated for the untrained person.
Feb 24, 2011 | Stoves 720EF Electric Double Oven
Fan oven does not heat up to correct temperature, but the light goes out so it thinks it does. Need new thermostat for the oven but where do I get one from. The oven is a 720EF Heritage
You can try espares. If it is not listed, there is normally a help section where you can send in a request. You will need the model number as well to ensure you obtain the right version. (It could be something like 059040415).
If you want to check what the oven is doing before buying the new parts, Lakeland do a reasonably priced oven thermometer, I think about 4 or 5 pounds to see what temperatures it is reaching. Also check the thermostat sensor. It is the long thin cylinder in the top right hand corner of the oven. It should be clean as a whistle and not covered in grease gunge etc. If it is, this could cause incorrect readings. Don't attempt to clean it manually as it is quite fragile, especially the connecting wire. Leave the sensor in situ and use a paste on oven cleaner which really works ( from Lakeland) and follow the instructions. it should come up bright and shiny. Best of luck.
Dec 10, 2010 | Stoves 720EF Electric Double Oven
Stoves 720 EF Electric Double Oven Model No 059040415 -when you turn the grill knob there is no light and it doesn't do anything at all - the grill is not working. However, the element must be working as...
First things first. The oven element is totally separate to the grill element. The clock has to have a time set for either the top or bottom oven to work, whereas the grill will work without the clock being set.
The control knob for the top oven is the ONLY control that will turn the top oven lights on, the grill does not turn the lights on. ( If you want to watch your toast, you have to turn the top oven switch on to the first setting as well as operating the grill control).
To prevent the grill being operated with the door shut, there is a micro-switch on the door hinge that allows the grill to operate ONLY when the door is down. The grill control also does not illuminate unless the door is down. There are two options on the grill control - right or left. One way is the inner element only and the other is both inner and outer ones.
So if you have done all that and it still doesn't work, then the micro-switch could be faulty.
Best of luck
Nov 23, 2010 | Stoves 720EF Electric Double Oven
Bottom oven is not working even though the top one is 720EF model
When you turn the bottom oven on, does the fan start to run in the oven? Do the oven lights come on? Does the main cooling fan switch on? Does the oven control knob illuminate? Does the thermostat neon illuminate?
As a guide, the power/control for the bottom oven is via the main switch on the front panel. Power then goes from the switch through the thermostat to the the oven/element/fan. The lights go direct from the switch.
I hope this helps.
Sep 17, 2010 | Stoves 720EF Electric Double Oven
Stoves 720EF - main fan not working
When you say the main fan, do you mean the background cooling fan or do you mean the circulating fan in the bottom oven?
Do you have the handbook for this oven as the wiring diagrams are included in it. If you haven't, you can take a copy from my BT Digital Vault - all I need is an email address to register you.
Looking at the diagram, the power for the cooling fan comes via the timer board. If, as you say, the fan doesn't work at all, the timer board could have gone faulty.
Nov 15, 2009 | Stoves 720EF Electric Double Oven
I have a stoves 720EF Heritage - electric - the top grill is not working - does it have a reset button?
No, there is no reset button. However, the grill will only work when the front is down as there is a microswitch which operates to provide connectivity when it is in this position. This is to stop the grill overheating. The switch could have gone faulty.
Does the top oven work ok?
When you operate the grill there are two options, part or full. Are they both failing? Does the cooling fan switch on when either grill is operated?
May 05, 2009 | Stoves 720EF Electric Double Oven
Stoves 720ef grill not working
The grills appear to be independant of each other. Does the oven still work and the oven light come on?
Depending on your answer it could be that the Top Oven Switch has gone faulty. The Grill Regulator and the Switch work together on the top oven. To get at both you will need to take the top of the oven off.
Oct 04, 2008 | Stoves 720EF Electric Double Oven
Stoves 720EF Electric Double Oven Logo
227 people viewed this question
Top Stoves Ovens Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
Are you a Stoves Oven Expert? Answer questions, earn points and help others
