SOURCE: lg tromm wm2277hw code de
Error Code "de" is for "door switch assembly faulty".
You can down load the service manual from this site:
http://136.166.4.200/contents/Laundry/WM2277.htm
Have fun!
SOURCE: My LG Tromm washer dryer ( WM3677HW or WD-12270RD)
According to the manual "water is overflowing (water level frequency is over 213). If FE is displayed, the drain pump will operate to drain the water automatically". Since there's nothing between the water inlet valves and the PWB I'd suspect that, but not before putting it into Test Mode to rule out other components and especially checking the water level detector switch The water level detector switch monitors the water level and feeds this information to the MICOM. The sensor reads air pressure in an air chamber on the tub. The air pressure changes in relation to the depth of the water, moving a diaphragm in the switch. As the water level fluctuates, it raises or lowers the iron center in the coil, which, in turn, changes the electric resonance of the oscillator circuit of which it is a part. As water level decreases, frequency increases. (e.g. A low water level may read 25.5kHz1 while a high water level may read 21.4 kHz. These readings are approximate; washers in the field may vary slightly from these figures.) To read the frequency while the COMBO is running, press and hold the SPIN SPEED and SOIL LEVEL buttons. The number on the display should be divided by 10 to obtain the frequency reading in kHz. A display of 254 would indicate a frequency of 25.4 kHz. The MICOM interprets the frequency reading as one of eight levels, with one being the lowest water level and any level greater than eight indicating an overflow situation.
SOURCE: my LG TROMM washer is
'de' stands for Door Error. There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor. Both require a service engineer's attention I suggest ;-0(
Good luck,
John C
SOURCE: I have washer machine wm2277hw LG., Tromm., this
Try to unplug your unit 15 minutes if show up again usualy bad hall sensor .. or overloading , unbalanced load ,,, try to level your washer to help your motor . Ty
SOURCE: lg tromm wd 85485 error code cl mean ?
Possible that the drain valve is clogged if the inlet line is working and so you need to remove the drain and back flush.Also check after the power plug is removed for few hours and see if the fault resets to start the machine only to show the error a few minutes later. if so clean the drain lines, check the inlet flow and the door switch.
