SOURCE: maax velvet bubble-tub does not work
This will tell you that the control board is bad. You will need to replace it. But before you do, make sure that the switch is telling the board to send the signal. Check to see if the board is getting the power required and that the poser is leaving the board.
SOURCE: find board for maax bubble-tub
You will probably have to go to the manufacture website to find a dealer in your area that you can purchase one from. Also, you can check online as well for specific parts for your tub. If often just google the brand and model number and start clicking on links to find what I want or need. Good luck to you!
SOURCE: Hydro maax wirlpool bathtub Model # J6061 Pump will start
Can either be a bad motor or if the motor has a capacitor, it needs to be replaced. I would call a service professional to come out.
SOURCE: I need to purchase the air hose that connects to
www.maax.com/Upload/guides/fr/000_10050073_0305.pdf
manual above.
http://www.uspartscenter.com/airswitchactuatorairswitchbuttonplug.aspx
link above is for air hose and switch
SOURCE: I have a maax hydro
Hi, the in-line water-heater temperature feature is designed to sustain the water temperature by automatically turning on when the whirlpool pump is activated.
