Question about Dometic Rooftop RV Air Conditioner
RV AC is working fine, but the water is leaking from the ceiling Where is the drain tube on the unit, The AC unit is a roof type, Duo Therm serial # 43404934, Part # 3105459
Posted by swimdad924 on
CamperRoofRepairKits
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 6 Answers
If your recreational vehicle's (RV) air conditioner is leaking, then it is probably time to replace the rooftop gasket that seals the unit. As this gasket ages, it becomes brittle, hard, and unable to seal the opening, thus permitting moisture to enter the RV. Replace an old gasket with a new one and eliminate a frustrating air conditioner leak. Another common culprit of leaking from the air conditioner into your RV is a clogged drain pan. Sometimes the drain pan gets clogged with dirt, leaves and other debris, prohibiting the water from draining through the small hole in the pan and onto the roof. Should this happen it is an easy fix and just requires a bit of clean out.
Posted on Aug 18, 2020
A Miller
  • 8,404 Answers
Normally, the condensate will drain out of the unit onto the roof and off the edge to the ground. Remove your cover inside (probably 2 screws) and tighten the 4 bolts you will find inside. If they are tight, go to your RV supply place and get new roof gasket. Remove the AC and insert the new gasket and resecure the AC to your roof.
Thanks for your question @ FixYa.com
Posted on Jul 26, 2011
2answers
I have a jayco pop up camper with a Duo-Therm BriskAir roof top a/c. im having problem with it leaking water inside of the camper? Is there a drain hose? Or wat do u think is wrong?Thanks
Yes there are drain holes in base of upper unit (on roof), which may be plugged. Couple of questions though to see if we can better troubleshoot this for you.
-Do you remember seeing water (condensation) running off roof before when AC was used?
-Have you cleaned filter inside at ceiling lately?
1helpful
My Dometic roof mounted aircon appears to discharge the water straight onto the roof. 1) Is this normal operation. 2) Is there a drain tube fitted, and if yes, where would I find it? Assistance will be...
Yes it is normal for AC to drain on to roof as the drain holes are in base of AC unit. The time to worry is when you don't see it draining on to roof, as this indicates holes may be plugged.
1helpful
3answers
I have a travel trailer with a coleman 7300 roof top ac unit. the unit will blow cold air but water leaks thru the plenum. i was told by the previous owner that it needs a new seal. i would like to fix it...
If it's leaking inside where filter cover is, then real good chance the drains being plugged is the only problem. If water (condensation) not running off roof when operating in cool mode, then I'd bet drains, which are located under unit on roof, and you should see them sticking down like buttons. They have a hole in side that needs cleaning with a pipe cleaner or similar to open them up. If need be, shut off power to unit and remove top cover on roof unit and look for the drain holes in base, and clean them out. If water comes in while raining, but AC not running, then it's gasket. That is remedied by removing ceiling assembly (just screws) and 4 bolts that pull/hold the upper and lower assemblies together, unplug wiring to upper unit, and simply lift it off, change gasket and re-install. Tighten those 4 bolts equally when gasket is aligned properly over hole, only until gasket is approx 1/2, original thickness. Plug harness back in and your done. (about an hours work.) Only other thing that may be wrong is styrofoam drip tray for cooling unit, under cover on roof may have a crack , allowing condensation to leak in. If that 's the case, you can try to find a sealant compatible with styrofoam to seal those cracks.
3answers
Water coming from ceiling about 3 foot from unit
Does the unit work other, than the leaking?If it does you need to install a square seal between the ac unit and the roof.You can either buy the seal from Ebay or I would recomend an Rv Repair place.(They Might even be able to install it where the Rv Sits)
3helpful
2answers
I suspect water is seeping in under my AC unit...
The roof A/C unit has a foam rubber seal/one piece gasket that fits around the part you see inside the coach but must be put in pklace before the unit is inserted in the roof opening. Replacing is relatively easy but you will need to remove the interior trim Disconnect the wiring from the coach to the unit and remove the four bolts holding the unit in place. Then lift out the A/C.to replace the seal. They do leak because of age and compression by units weight. Good Luck
On my 28 foot Itasca motorhome the air conditioner is leaking water through the gasket on the roof. I pulled the inside cover off and took out the four big boltd holding the roof top section, but I can't...
You need to find where the drain is. The water should flow to a drain and not into the unit. Once you get the condensation draining properly you can use a good quality silicone to seat around the unit. You might check at a RV parts place and find a product they recommend for RV roofs. Hope this helps.
Duo-therm brisk air AC unit leaks water into my RV when it rains
take the cover off and make sure the drain line is clear on top off RV.
Nov 15, 2009 • Ovens
3helpful
3answers
My roof top RV air conditioner is dripping water inside my RV
Check run-of on roof & see if it's been reduced lately, it may just be a plugged drain at base of unit on roof.
1helpful
My a/c is leaking from the ceiling of the rv. i cant tell exactly where, but something isnt draining properly. does anyone have a clue as to what i can do about this? my rv is a 1989 model. the a/c is cold...
Look between roof & base of AC unit for little round button like pieces sticking down, which are drains, that have holes in sides that get plugged up. poking with a piece of wire or similar in that hole may unplug it. You should see at least 2. Depending on what type of AC unit, it may just be holes in base for drainage, but if necessary to unplug, you can easily remove cover. Coleman has 4 big Philips screws on top to remove & dometic has a bunch of Philips screws around lower edge to remove & cover will come off, to check where plugged. Make sure power is off inside.(breaker) You should see a trail of water across roof from AC when running & cooling, if not plugged. There is the posibility of a cracked drainage tray allowing water to leak inside as well on some of the older models. You should be able to inspect all of that when cover is off on roof. P.S. CAREFUL! Observe before lifting cover off for wasps in the area, as not unusual for them to make nests under cover. Be prepared, or do on cloudy day, early in the morning, or near sundown when less active. Also, if dew on roof, could be slippery.
2helpful
2answers
RV Dometic AC Comfort Control Double EE Problem
I have a dometic duo-therm. The unit works great and fan blows strong and both high and low work., but air is coming out of the ceiling unit rather than the duct work. The bedroom unit works OK, but the air is strong out of one duct, and not much comes out of the others. The front unit only has air coming out on the A/C unit and none out of the ducts.
Dometic Rooftop RV Air Conditioner Logo
Top Dometic Heating & Cooling Experts
Dan Webster
Dan Webster
Jay Finke
Jay Finke
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
