Question about eMachines Computers & Internet
I have been having a problem with getting a white screen and have to jiggle to get the picture to come up, looked online and found where it might be a loose ribbon connection. Is there a way to fix without taking to a expert? Oh and yes, it was dropped a couple times by my 3yr old nephew. Thank you for your help and input.
Posted by diana62457 on
  • BSR Electronics Nov 23, 2017
    Could you provide more information in regards what the device is ?
    Also the make and model of the device for reference.
    Once we have this information we might be able to try and diagnose what the faults might be and the maybe able to offer you a solution.
    Thanks
    Garry
    BSR Electronics
5 Related Answers
Anonymous
  • 106 Answers
SOURCE: TH-50PX60U picture problem
Try to replace the Logic Scan board on the upper left side of your tv. The part no. is printed on the board and you can order it from Panasonic's Website. Also check the Service Manual for the part description and part no.
Posted on Jan 01, 2008
Anonymous
  • 76 Answers
SOURCE: Sprayed Screen
This is for SCREEN REPLACEMENT on PROJECTION TV's:
I replaced the screen on my 62 inch projection TV for about $50 and the the picture quality is good! Have a sheet of plexiglass cut to the EXACT size needed. BEFORE installation it MUST be frosted on both sides by either a fine particle sandblaster or by sanding it VERTICALLY on BOTH sides with a power sander and a fine grade paper.
If this is only an OUTER protective screen and the image is projected on the inner screen then DO NOT frost the replacement screen, just install it.
Posted on Mar 08, 2008
Anonymous
SOURCE: can't get signal from drc6309 to video/audio input
I dont have a Solution but I have the same problem with my RCA portable dvd DRC6309. I have connected it to three different tv set and I get no Video but I do get Sound through the tv sets... I have sent an e-mail to RCA costemer support hoping for a solution. If I hear anything back I will post it here...
I bought my RCA DRC6309 about a month or two ago at a Wal-mart supercenter. They no longer sell RCA portable dvd players. That is why I contacted RCA directly.
Posted on Aug 25, 2009
indy5155
  • 3 Answers
SOURCE: Side BY Side Picture On TV Black And White
My mother-in-law sent me her unit with the same problem. The problem i had was you couldn't really read anything on the screen in the setup menu. I finally got lucky and got in the right menu and set everything to default settings and it went right back. Here are the steps to reset it without reading it.
1. remove all tapes and discs
2 if your unit scans for channels when you turn it on press return once
3.if it doesnt go to channel scanning you should have a blank screen
4.press the functions button once
5.press down twice
6.press the enter button
7.press the enter button again
8.press down once
9.press right once
10.press down 4 times
11.press enter once
12.press up once
13.press enter once and the double image should be gone
14. press the functions button twice to exit
hope this works for you
Posted on Feb 06, 2010
SOURCE: sharp Lc-26sb24u white screen with sound
You will get a white screen when you unplug the t-con from the main board. Doing so removes power to the LCD panel. Verify that all of your voltages from the power supply are correct. If they are, I'd look at the t-con board. It sounds like there is a problem with the t-con that is pulling down the main board.
Posted on May 11, 2012
Samsung hd 14.2 mp 5x white screen no picture
T-con board has failed. You can replace this board yourself. You can get parts online from here TV Parts Universal TV Stands DLP Chips ShopJimmy
Aug 14, 2016 | Samsung Televison & Video
Screen white
Return it if the warranty is good. Otherwise find a repair shop that will look at it and tell you what is wrong, then find the part online and fix it yourself.
Mar 08, 2014 | RCA 26LA30RQD 26 LCD TVDVD Combo
Phillips Magnavox 9P6040 C104 tv color adjustment help
If you turn color off and stand back and examine the screen---if it is not black and white but yellow looking you have bad Glycol in the blue picture tube which is quite common.
Easy way to know for sure is with set on and rear cover removed peek with a small mirror at the three lens---don't touch anything with the set on===each tube red,blue, green should have a picture with the set on.
Likely you will find the blue one looks like a floodlight with little or NO image/picture.
May 18, 2012 | Hitachi Televison & Video
TV has white picture only
If your TV have sounds but no picture or image only white screen..
The possible problem is T-CON board..T-con board is the responsible for picture on LCD TV..
Please try to replaced it to get your TV back to normal operation...
For specific parts and easy find the it online kindly get the part # of the said board (part # is located on the board itself printed with sticker)..
search it online using that part #..
Hope it helps..
Feb 10, 2012 | LG 42LC2D 42 in. LCD HDTV
Problem with my Toshiba 27A44 television. The picture will be fine for maybe 20-30 minutes at a time, then acts up for perhaps 20-30 minutes, then may go back to working fine for a while (there is no set...
there are bad solder connections on the vertical output ic. if you can solder well, get an iron with a fine tip and look for an ic mounted to a metal heat sink. it will be about an inch or so long with 7-9 pins all in a row,on the under side of the board you can usually see the the rings around the pins if you look close or use a magnifying glass. i have fixed dozens of these using only a hot soldering iron and rosin core solder.
Aug 18, 2011 | Televison & Video
White screen on TV.
My TV does this too. i know how to remove the white screen but the top will still have power only vo4.52.00 to get rid of the white screen press 'return' on your TV remote (not direct tv remote) then change the input pack to whatever it is it needs to be on to watch your (whatever)
Apr 24, 2010 | LG 32LH30 32 in. LCD HDTV
My camera screen goes white everytime i turn on the camera
I Havee The Same Problem And Ive Been Reading Around And The Most Decent Answer I Found About What Was Wrong Was That Something Had Just Come Loose Inside So That Might Help Because Something Wiring Upo To The Screen Might Be Loose Its Worth A Shot.
Jul 26, 2009 | Fujifilm WL-FX9B 0.79x Wide Conversion...
Picture appears to be cracked
It is cracked. Maybe not the first layer, but for sure the lcd is cracked. This is the reason why you found it on the garbage. The lcd panel is way more expansive like the tv itself. You can sell it on ebay for parts.
Dec 31, 2007 | Samsung LN-S4095D 40 in. LCD HDTV
Beautifull picture except for a jiggling black line in pricure
your tv is having horizontal problem take it to a tech in order that the hrizontak deflection circuit be checked it also might have abad yoke
Dec 28, 2006 | Samsung TXF2899 28" TV
Computers & Internet Logo
Top eMachines Computers & Internet Experts
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
