Question about Mag Innovision LT776s 17" LCD Monitor
MY SCREEN GOES BLANK STAYS WHITE AND i HAVE TO EITHER UPLUG IT A FEW TIMES OR RESTART MY COMPUTER AND EVEN THEN SOMETIMES IT WONT WORK EITHER. IS THERE A WAY TO TROUBLESHOOT THIS? I HAVE NVIDIA DISPLAY ON MY MENU WITH A WHITE BOX THAT I CANNOT GET RID OF..... HOW CAN I RESET BACK TO THE ORIGINAL DISPLAY
Posted by catalinajr8 on
3 Related Answers
Anonymous
  • 198 Answers
SOURCE: MAG L765b Model 780
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Posted on Feb 20, 2008
Anonymous
  • 138 Answers
SOURCE: Screen goes white
Hi this is the way how to examine what's wrong with your LCD monitors. After you turned it on and the screen went white, you have to check that if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. This is because of the lamps inside screen. Some of them were broken and it is very easy to replace. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so. Hope this help!! If anything I can help you with, feel free to let me know.
Thank you,
Posted on Mar 07, 2008
Anonymous
  • 102 Answers
SOURCE: Monitor Display
see ur moniter is nearly dead...
dont try to on?off it again and again
take it to service center
it happened to me too
its nothing just a small thing which they will change it.
its a bit costy but not more then ur moniter
Posted on May 17, 2009
My laptop (compaq presario cq61) wont charge or turn on, even when plugged in. When I try to power up, the lights blink az few times, then goes off.
sounds like power charger not working properly or cpu is bad. this will happen sometimes too. it will turn on stay for a few seconds and then power down to prevent damagel
here is blink codes to help trouble shoot the problem
http://support.hp.com/us-en/document/c01732674#AbT2
Too many! Where do I start.... 1. The Wifi connection does not work, although blutooth is on and the blue indicator light is illuminated. 2. When the pc is idle for some time, the screensaver does not...
This can happen when there is two problems.. One the computer might have been affected by virus.. Or the other thing might be the OS corrupted.. Try to get into safe mode and check if the system is working fine.. If it works well there try to do a system restore to a place wr it was working well.. If in safe mode also it doesnt work well then go ahead and reinstall the OS...
1helpful
2answers
Syntax Olevia flat screen tv video goes off then on
Hi, Replace the bulging capasitors on the main power supply board. Thanks.
1helpful
Screen goes blank (white), sometimes screen display will get big
You can update graphics driver, if that does not fix the issue check the display on external monitor. If the external monitor works fine you can isolate checking the display in BIOS Setup scree (Restart your computer and keep tapping F10 to getinto BIOS). If the same issue in BIOS, you may have to change display of the unit.
My computer turns on sometimes the quickly goes blank. Other times, the On light comes on but the screen stays black and nothing seems to be moving inside.
try to desconnect or unplug your hard drive, if you see a black screen with a bunch of white letters, you hard drive is crashed, if not try to conect a second monitor (external) tru you vga connector, if work fine you have a lcd problem===>>>reemplace asap.
Acer9303 i have aproblem with the screen.sometimes when you turn on the computer the screen doesnt work and you have to move the lid to make it work.other times if you move the screen it goes white and you...
This is normally a screen cable problem. You must contact a computer technician to check the cable for you. If it needs to be changed, you will be told. Since it works when you move the lid, it should only be a cable problem.
Nano screen
why wont it charge
Sylvania (proview) cl2072b flat panel monitor
Well the first and second paragraphs make me say the Inverter/power board must be replaced.
A white display typically means either your display cable (in your monitor) is loose or logic board is dead.
Either one of these things typically mean take it in for an estimate to repair, and if it's too much, buy a new one.
With your luck I think I might switch to big cheap CRT.
Turn on computer sometimes it goes into Windows sometimes it doesnt
Right Click My Computer, Click Properties.
Click Advanced
Click Settings
Uncheck "Automatically Restart"
This will allow you to see the message that caused the restart.
Sounds like its memory, or the mainboard.
Mag Innovision LT776s 17" LCD Monitor Logo
Top Mag Innovision Computers & Internet Experts
Ekse
Mandeep  Singh
Mandeep Singh
Are you a Mag Innovision Computer and Internet Expert? Answer questions, earn points and help others
