How many years do you own that desktop computer? You have a problem with your Ram: Transcend: 2GB 1333 Mhz
Ram is always responsible to boot and run all system required by your computer
A defect ram cannot boot or not properly run application e.g.
Power-On-Self-Test (start up of your computer)
Booting your Operating System
Running your Application like Microsoft office , Photoshop and so on
Replace your Ram
Dear jrmenor2011, this system described here is about 8 months old. Of course, I'm arranging for a brand new ZION DDR-3 (Hynix Chip) RAM to replace that said one as you prescribed. Now, please tell me while older CPUs like dual core with system boards even start without a RAM and beeps "RAM error", isn't DH55TC's characteristics same? Does Core i3 starts without a RAM?
To roy,
You need a RAM in order to start up all things when you push the power button of your computer. As I prescribed, RAM is "always" responsible to boot up the system
I'll give you a tip, before you buy a hardware for your computer, always check your desktop motherboard's manual for hardware compatibility (e.g. RAM)
I have installed a brand new ZION DDR-3 (Hynix Chip) RAM, but the problem persists. When i switch the system on, no response from the system. SMPS, CPU Fan doesn't start, no power on light, no beep sound, only tiny LED on M/B shows there is power on M/B.
do you try to manually configure your jumper settings on your motherboard? You said that the LED shows that there's a power on it but doesn't start. Try to put a jumper on the power on connector on your motherboard. If it works, you have a problem on your desktop housing's power button. Then check again your motherboard manual for jumper configuration settings
