Tip & How-To about Panasonic Panafax UF-560 Plain Paper Laser Fax
Panasonic Fax Machines uf-560 thru uf-990 Drum Shutter Jamming
Remove and discard the drum cover on the bottom of the cartridge, they come unhooked and cause jamming. It's only there for shipping.
Panasonic Panafax UF-560 Plain Paper Laser Fax Logo
How Do I Open Samsung Xpress M2070w printer machine to Remove Paperjam
1, Paper jams occur when papers are stuck inside the laser printer. It affects the entire printing process. Lift the scanner unit and open the jam cover. Raise the fuser dummy cover. Discard the jammed paper by pulling it outwards gently. Close the fuser dummy cover and the jam cover.
2, Lower the scanner unit. Open the middle cover and take the toner cartridge from its slot. Remove the jammed papers and reinstall the toner cartridge. Close the middle cover and the scanner unit.
3, If the paper jam error still occurs, look for paper jams in the input tray area and remove them.
For more printer related queries get in touch with our experts by just giving a call @ 1-866-293-9220
I got always the message Print Head not installed
follow these steps:
1.
Turn the open the top cover. Wait for the cartridge carrier to stop moving, then lift the first cartridge out of the printer. Tilt the cartridge forward, then carefully lift it out of the printer.
2.
Examine the electrical contacts on the bottom of the cartridge. Look for any tape that might be covering those contacts. New print cartridges ship with this tape to protect the cartridge and prevent leaks. If you fail to remove this tape, the printer cannot sense the cartridge and it might return a "print head not installed" error.
3.
Remove the rest of the cartridges from the printer. Check them for tape and other obstructions. Also check the cartridges for leaking ink, and clean them if necessary. Discard and replace any cartridges found to be leaking.
4.
Clean the ink cartridge carriers thoroughly, using a soft cloth or a small vacuum cleaner designed for cleaning computer components. Paper dust and ink residue can accumulate in the carrier and cause communication issues with the printer.
5.
Place the ink cartridges back in the printer and close the top cover. Power cycle the printer if the error message does not go away immediately.
in case of any additional help, please revert back
2answers
error: open upper cover exit jam
Feed Jam or Exit Jam ecblank.gif ecblank.gif dot.gif ecblank.gif 1. Remove the tray and clear any misfed sheets as given above.
2. Open the top cover.
WARNING! The fuser area will be hot. This area is clearly marked. Do not touch it.
CAUTION! Never expose the image drum unit to light for more than 5 minutes. Never expose the image drum unit to direct sunlight. Always hold the image drum unit by the ends or from the top. Never touch the surface of the green drum inside the image drum unit.
3. Carefully lift out the image drum, complete with the toner cartridge. Be careful not to touch or scratch the green drum surface.
4. Remove any jammed sheets from the paper path.
5. Re-install the image drum complete with toner cartridge, ensuring that it correctly locates into the slots on each side of the printer.
6. Close the top cover and press down to latch it closed.
7. The printer will warm up and commence printing when ready. he page lost through the jam will normally be reprinted.
NOTE If the edge of the jammed paper protrudes (or can be seen) from the exit, reinstall the image drum, close the top cover and switch the printer on. Remove the jammed paper from the exit when the exit roller begins rotating after a few seconds after switching on. However, if the jammed paper cannot be removed, contact a service representative.
panafax uf-885 will not print
You will need a flashlight!
Open the toner door, remove the toner cart.
Look in the cavity towards the bottom left side
You should see 2 spring loaded loops sticking up.
One or both of them is probably bent down and not making contact with the silver tabs on the bottom of the toner cartridge.
Also, remove and discard the plastic drum cover that swings back and forth.....it's only for shipping, it causes many jams.
Try to bend the loop back up with your finger.
Repost if you can't get in bent straight up and I will help you further.
Clothes get caught between drum at front of dryer
the drum has either worn out its felt(front), a fabric bearing, or the roller(rear) bearings, or both, and dropped enough to make a gap. new rollers are3 about $15 /pair, felts between $13 & $90 depending on model.
Generic replacement is simple, and really while you got it apart, do both, the strain of twisting off axis will make the remaining good end fail shortly
The generic steps may not be correct for the actual dryer model.
Felt seal
for most dryers,
Go buy HiTemperature silicone adhesive (tube)
tools required couple pairs locking pliers/visegrips screwdrivers
Unplug dryer
remove the front cover, either
  • couple screws at the bottom and spring clips to pop off with a screw driver OR
  • couple of spring clips to hold the top lid on, then screws top and bottom of both sides
    examine the case to find the exact mounting
unclip cables from door switch
set front panel aside
unhook drive belt from tensioner pulley
pull drum forward and out
remove old felt
scrape off old adhesive
put adhesive per instructions (some 2 surfaces some 1) on drum/felt
clip felt in place on drum with visegrip at 1 point
stretch felt around drum, gluing and clipping in place with vicegrips as you go
allow glue to set
reassemble in reverse order
Roller bearings
for most dryers,
tools required needle pliers/visegrips screwdrivers
Unplug dryer
remove old rollers:
  • pry triangular circlip from axle post
  • discard circlip
  • remove and discard roller
  • install new roller
  • install new circlip
    ALWAYS replace rollers in pairs
wow took longer to type than it actually takes to do it
Jul 22, 2008 • GE Dryers
Top Panasonic Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
