Question about HP ProLiant ML370 G4 Server
SOURCE: problem with scsi driver proliant ml 370 for NT4
Are you attempting to boot from the Windows CD?
If you are booting the server from a Windows installation disk and it is unable to detect the hard drive, this typically means the following things.
You need to provide the driver for the RAID controller of the server (this can vary, depending on the version of the ML370 e.g. G4/G5)
If it still cannot detect the hard drive after providing the driver for the RAID controller or if there is not a driver available for NT4, it may not support the controller.
In this case you can remove the RAID set by entering the RAID setup (could be LSI or adaptec). NOTE THIS WILL DESTROY ALL DATA ON THE DISKS THAT ARE A PART OF THIS RAID SET.
Posted on Dec 28, 2008
SOURCE: HP Proliant ML 370 G3 the server is got hung
Check if the processor fan is running properly. Also check the RAM modules, as these could sometime cause the machine to hang.
Posted on Aug 04, 2009
Jan 17, 2013 | HP Compaq ProLiant ML310 G4 Server
Nov 29, 2012 | HP Compaq ProLiant ML370 G3 Server
May 19, 2012 | HP Compaq ProLiant ML350 G4 Server
Jan 07, 2012 | HP ProLiant ML350 G4p Server
Jul 08, 2009 | HP Compaq ProLiant ML370 G3 Server
May 11, 2009 | HP ProLiant ML370 G4 Server
Dec 26, 2008 | HP Compaq ProLiant ML530 Server
Oct 29, 2008 | HP Compaq ProLiant ML530 Server
Nov 11, 2007 | Compaq Refurbished PRLNT ML370 G2 POWER...
Sep 23, 2013 | HP ProLiant ML370 G4 Server
155 people viewed this question
